need help asap
ok so i did a wire tuck on my car well just turn signals and i move fuse panel on passanger floor put my engine in and i wanted to start it so i turn the key and the lights were on and i tryed to turn it over it made a click and all the dash lights and everything shut off and i checked the fuses and nothing that i could see was blown can you help me thanks...
i had the car on the charger everything worked lights and everything cause when i didnt have a motor i tested all the lights everything worked i just dont know i check fuses and they lookedd good i got the car on a battery charger i even tryed jumping and using a new battery
do you have a super rare invisible radiator??
i think its something you messed up when you did the wire tuck. make sure all those connections are secure and try to start it up again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jussstin »</TD></TR><TR><TD CLASS="quote">do you have a super rare invisible radiator??
i think its something you messed up when you did the wire tuck. make sure all those connections are secure and try to start it up again</TD></TR></TABLE>
yeah, sounds like a BAD GROUND, sae thing happen to me just add a few new ground wire and make sure everything is tight and touching metal.
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
callmechad
24
May 9, 2009 03:52 AM
cademan
Jul 19, 2004 03:42 PM
