Intake Air Temperature Valve Cleaning???
Old Jan 11, 2008 | 11:39 AM
JDM EJ2's Avatar
Default Intake Air Temperature Valve Cleaning???
Hey does anyone know if I can clean this little SOB because its the only code showing up after the swap. If I can what do I do? Thanks.
Old Jan 11, 2008 | 11:42 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Intake Air Temperature Valve Cleaning??? (JDM EJ2)
Dont think you can clean them, just replace them.. they dont cost much.. if thats what for sure is wrong
Old Jan 11, 2008 | 12:38 PM
klungemonger's Avatar
What exactly do you mean...because there isn't really any such part. You have 2 things combined:
Intake Air Temp Sensor (IAT) or
Idle Air Control Valve (IACV)
There generally isn't a need to clean the temp sensor, but people do sometimes clean out the iacv
Old Jan 11, 2008 | 12:44 PM
havok hybrid's Avatar
Default Re: (klungemonger)
you can burn them up.. if you plug in the wrong harness plug to it.. and power it up.. it will burn.
get one off a sohc motor ..or another motor... there all the same... 88-00
Old Jan 11, 2008 | 12:47 PM
speedooo's Avatar
Default Re: (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">you can burn them up.. if you plug in the wrong harness plug to it.. and power it up.. it will burn.
no theyre not. iat on 88-95 in the white sensor on the back of the intake manifol. 96-00 is the sensor in the intake arm
Old Jan 11, 2008 | 01:37 PM
Relic1's Avatar
which one do you have?
10 - IAT
14 - IACV
the IAT CEL right after a swap is a common problem.
cause: the EVAP purge and IAT plugs are switched.
solution, replace the IAT, switch the plugs so they are correct.
IATs seldom go bad under normal operation.
IACVs on the ohter hand are different. The random bumping around and various smacks that the AICV gets since it's mounted to the outside of the intake mani tend to screw it up.
simply replace it.
Tim Verway
Engine Management and Tuning
Feb 13, 2012 11:23 PM
marcj
Sep 24, 2008 08:38 AM
5genhatch
Sep 18, 2004 09:35 PM
:mR. PotAtO heaD:
Jun 17, 2004 03:28 PM
vteczone
Nov 8, 2003 09:09 PM
