Snapped Studs/Bolts
Old Jan 11, 2008 | 09:40 AM
Importcustomx's Avatar
Default Snapped Studs/Bolts
So...
i snapped a stud when taking off the oil pan..its stuck in there..i cant get it out.
when i do get it out how do i sink the new stud in there and make sure its secure?
Same thing on my header...i snapped 2 studs on the header also..
HELP..is there a special tool to sink the studs that i dont know about or something. any help would be great.
thanks guys
Old Jan 11, 2008 | 10:33 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
gringing wheel and a left handed drill bit never failed me.
Old Jan 11, 2008 | 04:26 PM
Default Re: (ComeOnKip)
yes but how do i get the new studs back in..i know how to get the old ones out..the question is HOW DO I GET THE NEW STUDS IN
Old Jan 11, 2008 | 06:25 PM
GSX 4G63T's Avatar
EZ out kit to remove broken studs. and helicoil to make threads with tap.
Old Jan 11, 2008 | 10:55 PM
michael O's Avatar
Default Re: (4163175587)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">EZ out kit to remove broken studs. and helicoil to make threads with tap.</TD></TR></TABLE>
yea. Snapped studs/bolts are a pain in the ***. Invest in these and u should be good.
Old Jan 14, 2008 | 07:20 AM
Default Re: (michael O)
Those helicoils...how do those work....do they slide in? sorry ive never seen that before.
im curious how those work..i got the easy out kit..ive used a traditiional dye and tap set before..but my question is how do i get a stud back in?
Old Jan 14, 2008 | 07:48 AM
xXx Justin xXx's Avatar
Default Re: (Importcustomx)
the stud will have a section without threads... you can try to take the nut and thread it all the way up, and use it to thread the stud in tight, but that might make it hard to get the nut back off without the stud coming out, unless you use some type of locktitie on the stud and let it set for 24 hrs. a helicoil i think is for when your threaded hole is stripped out too big for tap/die to fix. It is like an insert sleeve that would provide a new threaded hole.
if you have something small enough to clamp onto the non-threaded portion of the stud, and use that to tighten it (like needle nose vice grips), you could also try that. Just be careful not to slip and mess up the threads.
Old Jan 14, 2008 | 11:44 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
To reinsert the studs,
Place two nuts together on the stud
and tighten them against each other..
You can then tighten the stud into place
using the jammed nut..
kornerk12
13
Aug 7, 2009 02:46 PM
timmy0tool
10
Dec 19, 2007 03:25 PM
DJslepton
11
May 31, 2006 05:43 PM
BumpinVTEC
Oct 3, 2003 10:58 AM
