Rusted radiator question?!?
Old Jan 11, 2008 | 08:51 AM
I CRX I's Avatar
Default Rusted radiator question?!?
my friend just gave me a new radiator (well newer then mine) and i was going to swap it out with mine old beat up one but i noticed if i looked inside of the radiator cap, theres what appears to be rust on the fins inside. the radiator is in alot better condition then my crx's , and its thicker. i currently have a gsr in my car and wanted that extra cooling but im afraid that bit of rust is going to screw up my motor. another friend of mine said it shouldnt be a problem if i just run the motor for a while and let the hot coolent break everything down then just swap it out with fresh fluid. should i risk it? p.s. i got the radiator for free.
Old Jan 11, 2008 | 08:56 AM
JustAnotherRex's Avatar
Default Re: Rusted radiator question?!? (I CRX I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">my friend just gave me a new radiator (well newer then mine) and i was going to swap it out with mine old beat up one but i noticed if i looked inside of the radiator cap, theres what appears to be rust on the fins inside. the radiator is in alot better condition then my crx's , and its thicker. i currently have a gsr in my car and wanted that extra cooling but im afraid that bit of rust is going to screw up my motor. another friend of mine said it shouldnt be a problem if i just run the motor for a while and let the hot coolent break everything down then just swap it out with fresh fluid. should i risk it? p.s. i got the radiator for free. </TD></TR></TABLE>
I wouldn't deal with the risk, I doubt you'd have any problem, rust does happen and the block is aluminum, but still, I wouldn't want to have that in there either way.
If there is a ton of crap in the old radiator you could try flushing it out first and see if that helps any; you don't want to clog anything in the cooling system.
Otherwise I'd guess there isn't really much to go wrong.
Old Jan 11, 2008 | 02:03 PM
I CRX I's Avatar
Default Re: Rusted radiator question?!? (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">
Otherwise I'd guess there isn't really much to go wrong. </TD></TR></TABLE>well my old one doesnt have much crap in it, its just old and has a hole about the size of a penny in the fins. aside from that, the radiators good but damn near as thin as a pencil. the other one is in way better shape, its just been sitting for a while. but like you said, i just dont want to risk it if its possibly gonna cause issues.
Old Jan 11, 2008 | 03:31 PM
wiZCo's Avatar
Stouts 'n' Scotch
Don't do it. Just get a new one. If it has rust it in it's probably not going to last very long either.
Old Jan 13, 2008 | 08:39 PM
LatnKng's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Don't do it. Just get a new one. If it has rust it in it's probably not going to last very long either.</TD></TR></TABLE>
WISELY put WIZCO...true..it may run for a few days, weeks, months, but then again it could breakdown the day after you decide to keep it and run it...i'd say get a new one and dont worry about it messing your motor up or being rusted...definately...i wouldnt want to drive around wondering when my car might breakdown on me or something...GET A NEW ONE...def.
Old Jan 14, 2008 | 09:42 AM
twiztid17thninja's Avatar
Default Re: (LatnKng)
get a new one, radiators often have rust but you have an expensive engine and it sounds like the rust is pretty bad.
Old Jan 15, 2008 | 08:22 AM
LatnKng's Avatar
Default Re: (twiztid17thninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid17thninja &raquo;</TD></TR><TR><TD CLASS="quote">get a new one, radiators often have rust but you have an expensive engine and it sounds like the rust is pretty bad.</TD></TR></TABLE>
Thank You...the motor is expensive, so definately getting a new radiator would ease worries off your mind. Just a thought.
leono
Jun 23, 2005 10:44 PM
missionaryrider
Jun 21, 2005 09:19 PM
tkHBseries
Feb 19, 2005 06:48 PM
mrlegoman
Welding / Fabrication
Jan 4, 2005 05:39 AM
hybridcrx
Oct 18, 2004 10:11 AM
