Fast idel valve under oem b16a throttle body ?
i think thats the fast idel valve underneath the oem b16a throttle body ,but i got a skunk2 throttle and there is no place for that fast idel valve. should i just eliminate it or relocate it or ? and the vacume hoses on the oem throttle body, there are none of those connectors on the skunk2 throttle body.
need advise please.thanks
If there's no place for it, just splice the in/out coolant line together and ditch the valve. It only controls the high idle when the engine is cold (works like a T-stat) and heats up your TB when the car is warm resulting in higher intake air temps.
I'm assuming that Skunk 2 doesn't feel that this functionality is necessary for a race application and designs their TBs appropriately.
However, since I have no specific personal knowledge of the S2 TB, make sure there aren't any ports that are left uncovered and would introduce a vacuum leak if you delete the valve.
Spawne32
Mar 1, 2013 04:55 PM
TuningBrasil
Jun 5, 2008 06:06 PM
