90-91 y1 b16 gears onto 92-93 ys1 counter and main shafts
Old Jan 11, 2008 | 07:44 AM
92DAIntegraXSI's Avatar
Default 90-91 y1 b16 gears onto 92-93 ys1 counter and main shafts
ok i picked up a y1 b16 cable trans from a buddy for dirt cheap. has a messed up reverse and possibly 3rd gear. basicly reverse wont engage because of the teeth messed up on first. in the car now i have a ys1 case with 99 gsr gear set. the case has been modified to accept a hydro lsd which i have yet to install. now will the gears from the y1 tranny work on the GSR counter and mainshaft? or are they to small? i kno the counter shaft itself will not work on the car because of my clutch. im just curious on the gear swapping. tried searching didnt get a str8 answear
Modified by 92DAIntegraXSI at 3:44 PM 1/11/2008
Old Jan 11, 2008 | 02:44 PM
Default Re: 90-91 y1 b16 gears onto 92-93 ys1 counter and main shafts (92DAIntegraXSI)
bump
Old Jan 11, 2008 | 03:23 PM
mmuller's Avatar
Mad Scientist
no work
Old Jan 12, 2008 | 08:55 AM
Default Re: 90-91 y1 b16 gears onto 92-93 ys1 counter and main shafts (mmuller)
could you explain why with a educated answear instead of " no work"
Old Jan 13, 2008 | 05:25 PM
StorminMatt's Avatar
Everything is different between the Y1 and YS1. Although the YS1 is a cable transmission, the internals are actually more similar to the hydraulic transmissions.
Old Jan 14, 2008 | 07:11 AM
Default Re: 90-91 y1 b16 gears onto 92-93 ys1 counter and main shafts (StorminMatt)
thanks thats all i needed to kno. i kno the ys1 stuff is simialr to the hydro thats why im running the 99gsr internals at the moment. i fixed the revers gear with one fomr a ysl ls. fit perfectly. now all i ned to get is the third gear and a 90-91 clutch disc.
crx-si
Transmission & Drivetrain
Feb 2, 2012 09:58 PM
92DAIntegraXSI
Jan 11, 2008 07:42 AM
RHDintegXsi
Aug 24, 2007 08:59 AM
dustin_crxsi
Jan 29, 2007 08:08 AM
