1st b Series swap experience...
Old Jan 11, 2008 | 02:43 AM
HondaTeKnology's Avatar
Default 1st b Series swap experience...
I have never done a swap before but would like to learn. Ive read its easy and cheaper than have a shop do it. I know its going to b a pain in tha a*s but what the hell. I have a compressor I know i need a cheery picker what else do i need? How was your first swap experience like guys???
Old Jan 11, 2008 | 03:27 AM
RIZOBIZERT's Avatar
Default Re: 1st b Series swap experience... (HondaTeKnology)
Do some research, I'm quite certain this has been covered. B swap shouldn't be an issue for you. It's plug and play for the most part (depending on your model) and if you do need something, someone makes it. Yes, do it yourself, it's a good learning experience and you're not reinventing the wheel, so if you have questions as you go help will be there.
Old Jan 11, 2008 | 05:02 AM
crazyguy's Avatar
first of all , u need to get your b series swap complete and ready to be dropped in. second of all. get all the tools you needed and a heavy duty jack and engine hoist. third, i think u need at least help from a friend/family member. 4. a lot of patient and time to spare for your first swap.
i guess, do i over the whole weekend. like sat. take out the old swap and clean the engine bay and stuff. and sunday put the swap in and put everything back together.
u will need to remove both axles, unbolt 3 motor mounts. tranny torque monuts.ac torque mounts and disconnect plugs from driver side firewall and battery . i always removed radiator and ac condensor so they dont get in the way. and pull the engine out slowly. installation is the the reverse of removal.
it is not hard.but time consuming
Old Jan 11, 2008 | 05:27 AM
antiJDM's Avatar
i did my first swap by myself with no more than a cherry picker and hand tools. i've never used an air compressor on a swap.
just make sure you have the right motor mounts, and the motor has the same corresponding obd series...if it's an obd1 car, it's easiest to swap in an obd1 motor. mostly just to prevent wire splicing and swapping connectors...the last thing you want to do is find yourself in a mess of wiring...especially being your first swap. i'm not saying obd2 motors (or obd0 for that matter) can not be swapped in to an obd1 car, i'm simply saying that it's much easier. you will be able to use your factory engine harness in most cases.
sites to reference:
here, search archives
http://www.hondaswap.com
http://www.mpfi.org (mostly obd0 stuff)
http://www.ff-squad.com (haven't been on that site in a while, not sure if there is much tech on it)
good luck, don't rush anything.
Old Jan 11, 2008 | 06:12 AM
B18C5-EH2's Avatar
Former Moderator
Loved
https://honda-tech.com/zerothread?id=131949
Also general FAQ list - may have some extra info:
https://honda-tech.com/zerothread/1998336
Old Jan 11, 2008 | 06:28 AM
Tuner Eddy's Avatar
the h-t FAQ is very helpful, but do you have anyone around you that can help? I lucked out a got a job with a tint shop when i was younger that also did motor swaps on the side. After you see about 2 swaps done on a honda, you can do a million of them. I have done 7 or 8 swaps, several clutch installs, and never paid a dime for anyone to work on my car.
experience is the key!
Old Jan 11, 2008 | 06:58 AM
crazyguy's Avatar
Default Re: (Tuner Eddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner Eddy &raquo;</TD></TR><TR><TD CLASS="quote">
experience is the key!</TD></TR></TABLE>
100% agree.
Old Jan 11, 2008 | 07:05 AM
instrument's Avatar
swapping a motor is pretty easy as long as you've taken good care of your car.
swapping a motor on a car that has never had its suspension taken apart/bolts unloosened/ etc...thats completely different.
Old Jan 11, 2008 | 07:08 AM
crazyguy's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">swapping a motor is pretty easy as long as you've taken good care of your car.
thats also true too. the more u mess around with your car. the more experiences and lesssons u will learn.
Old Jan 11, 2008 | 08:38 AM
Panda Eg6's Avatar
Default Re: (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
thats also true too. the more u mess around with your car. the more experiences and lesssons u will learn. </TD></TR></TABLE>
x2
Freemananana
17
May 29, 2014 06:58 AM
BrianB16A2
K Series
10
Jan 15, 2014 03:07 PM
96-wagon-boy
Jul 28, 2012 05:40 PM
jdmanglerking
Mar 26, 2010 09:00 PM
