HAS ANYONE TRIED THESE SPACERS THAT CONVERT YOU 4X100 TO 4X114?
Old Jan 10, 2008 | 10:54 PM
1da62c's Avatar
Default HAS ANYONE TRIED THESE SPACERS THAT CONVERT YOUR 4X100 TO 4X114?
I SAW THESE ON EBAY AND JUST WANTED TO GET SOME INFO ON IT AND IF ANYONE HAS TRIED THEM OR HAVE THEM ON THERE CARS. THEY ARE 15MM THICK
Old Jan 10, 2008 | 11:02 PM
Lasty K's Avatar
Some guy sells the 4 lug to 5 lug conversion spacers like those, he says they work fine l0l.
Old Jan 10, 2008 | 11:37 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Lasty K)
Old Jan 11, 2008 | 12:41 AM
toyomatt84's Avatar
Sanji
I have a set, and I wouldn't trust them for track use. But, for show purposes, they're just fine.
Keep in mind, the wheels you put over them will need clearance for the 4x100 studs.
Old Jan 11, 2008 | 01:13 AM
Desired_Speeds's Avatar
ive always thought about how dangerous those would be..
Old Jan 11, 2008 | 01:17 AM
iamhollywood[BRS]'s Avatar
wow, just... wow.
Old Jan 11, 2008 | 02:26 AM
VRD^sam's Avatar
Default Re: (iamhollywood[BRS])
Old Jan 11, 2008 | 03:01 AM
iam7head's Avatar
Default Re: (VRD^sam)
check out how much clearance you will get with a set of those, you probably need 50-60 et for stockish look with those spacer/adopter
Old Jan 11, 2008 | 03:02 AM
iam7head's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">I have a set, and I wouldn't trust them for track use. But, for show purposes, they're just fine.
Keep in mind, the wheels you put over them will need clearance for the 4x100 studs.</TD></TR></TABLE>
dont worry, it will not pass inspection
Old Jan 11, 2008 | 03:16 AM
toyomatt84's Avatar
Sanji
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
dont worry, it will not pass inspection </TD></TR></TABLE>
What inspection? There's no "inspection" here in Wisconsin.
Old Jan 11, 2008 | 03:58 AM
TurboKneeGrow's Avatar
My only question is why? What advantage does a 4x114 have over the 4x100 if you aren't getting the type r brakes with them. Except for maybe putting the 4x114 type r wheels on your car.
And if this is the fact you couldn't even put the type r wheels on there. you would just be mouting 4x100 wheels from the 4x114 holes.
Maybe I'm way off but I just dont see an advantage to these. In the end the only thing you are getting is the spacer and then you might as well get a regular 4x100 spacer.
Old Jan 11, 2008 | 04:06 AM
toyomatt84's Avatar
Sanji
Default Re: (TurboKneeGrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboKneeGrow &raquo;</TD></TR><TR><TD CLASS="quote">My only question is why? What advantage does a 4x114 have over the 4x100 if you aren't getting the type r brakes with them. Except for maybe putting the 4x114 type r wheels on your car.
Maybe I'm way off but I just dont see an advantage to these. In the end the only thing you are getting is the spacer and then you might as well get a regular 4x100 spacer.</TD></TR></TABLE>
I said, if you're going for "show purposes". It's simply so you can run some 4x114.3 wheels on a car that isn't equipped with that bolt pattern. A lot of wheels have solid hub designs, so they wouldn't work with these converters, because there's no clearance at all for the existing studs. But, there's probably just as many (if not more) that do not have solid hub designs, and can clear the stock studs just fine (I happen to have 4 sets of wheels that are 4x114.3 that run perfectly fine on my stock hub Civic).
Old Feb 10, 2008 | 11:44 AM
<StevieG>'s Avatar
sounds good thats why i bout those exact converterslol
Old Feb 10, 2008 | 11:51 AM
A_P_1's Avatar
Default Re: HAS ANYONE TRIED THESE SPACERS THAT CONVERT YOUR 4X100 TO 4X114? (1da62c)
How about just keep it 4X100?!
Old Feb 10, 2008 | 11:59 AM
CarbonEGG's Avatar
What inspection? There's no "inspection" here in Wisconsin. </TD></TR></TABLE>
Inspection when you go to the track. And by saying when "you" go to the track I am not talking about you,lol
I dont want you to say.. "I dont go to the track"
Old Feb 10, 2008 | 12:08 PM
Ep1dem1c's Avatar
stop yelling
.Hatches.'s Avatar
VW owners use these all the time. I have never heard a problem with them.
Old Feb 10, 2008 | 12:26 PM
does_it's Avatar
this is true vdub guys use these all the time with no complaints!
h3ll0Kitty
May 18, 2005 12:46 PM
Larkin W.
Mar 15, 2005 06:26 PM
JohnnysEG
64
Nov 21, 2004 02:58 PM
Hacemuy
Apr 1, 2004 05:43 PM
BoostedH23a1
Nov 16, 2002 02:47 PM
