Very bad suspension problem!!!!
Old Jun 30, 2002 | 11:57 AM
born2speed's Avatar
Default Very bad suspension problem!!!!
I just figured out what this bangin noise I've been experiencing is. It is my control arms hitting my body, you can actually see that the metal has bend bent from so much hitting. I don't know much about suspension components, but I do't think I have any bumpstops. Is this the reason for the control arms hitting the body?
Also I was trying to adjust my ride height and the right side will not level with the left side. My right side is a good 1/4" higher than the left even though the perches are a 1/4" lower on the right than the left.
Can anyone help me!!!!
Old Jun 30, 2002 | 07:44 PM
IN VTEC's Avatar
Default Re: Very bad suspension problem!!!! (born2speed)
How much did you lower the car?
Old Jun 30, 2002 | 08:02 PM
AcuraRacer112's Avatar
Default Re: Very bad suspension problem!!!! (IN VTEC)
? ummmm how low is your car ?
Old Jun 30, 2002 | 08:35 PM
M0NEYnH0s's Avatar
hmm, out of curiosity whats the banging noise sound like and when does it occur.
Old Jul 1, 2002 | 04:23 AM
born2speed's Avatar
My car is lowered about 1.5 - 2 inches (there is 1 figure gap on the left and 1.5 on the right).
It sounds like a loud bang and it happens when going over bumps or crevaces.
Old Jul 1, 2002 | 12:18 PM
vteg's Avatar
New User
What is the spring rate on the coilovers you have, and how much bumpstop do you have left.
Old Jul 1, 2002 | 01:02 PM
born2speed's Avatar
Default Re: Very bad suspension problem!!!! (vteg)
im not exactly sure on the spring rates, I'm waiting for Weapon-R to call me back.
To be honest I'm not sure if the bumpstops are there. I'm not sure if I'm looking for the right thing. Can you physically see the bumpstops when looking under the car. All I see is a peice of metal or rubber around the shock rod that is flush with the top (right where the body is).
da_33
Jul 10, 2007 03:21 PM
dpkelly
Mar 19, 2007 10:23 AM
eMpAtHy
Suspension & Brakes
May 12, 2005 12:38 PM
grampafunk
Apr 5, 2005 09:03 PM
justininhifi
May 1, 2003 06:03 PM
