B18 block/B20 Head
Old Jan 10, 2008 | 09:09 PM
Ebrake650's Avatar
Default B18 block/B20 Head
The engine is installed in the car but wont start. the engine is getting fuel and spark but it wont start i changed the ECU to a PR4 i used a 90 ls distributer. if any can think of something that might be wrong please help out. Also i wanted to upgrade the headers any one know what year of integra headers fit without to many customs.
Old Jan 11, 2008 | 10:46 PM
sinfulrides89's Avatar
Default Re: B18 block/B20 Head (Ebrake650)
have you checked your compression? i swapped a B back into my integra and it had 0psi at all cylinders. head could be warped, rings could be fried, or you could have a burnt valve. i dont mean to rain on your parade im just givin the possibilities.
email me and let me kno how it goes. (sinfulrides89@yahoo.com)
if a dry compression test doesnt turn out good try a wet compression test.
pour a little oil in each cylinder and check it again. if theres still no compression its a head problem. if you gain compression your piston rings are fried.
get back @ me bro.
Old Jan 31, 2008 | 03:20 PM
fin781's Avatar
Default Re: B18 block/B20 Head (sinfulrides89)
also check your wiring harness. check our grounds there is a main ground near the thermo stat, i left it off once, and well, it would fire . freespin
killer833
Dec 6, 2013 06:21 PM
lopezchris21
Feb 15, 2010 08:24 PM
Japankid
May 26, 2009 11:30 AM
GsrIntegra789
14
Jan 5, 2008 08:20 AM
gsrboi80
Jun 8, 2005 05:11 AM
