MY TAIL LIGHTS RANDOMLY STOP WORKING!!! HELPPPPPPP!!!!!!
I just bought a '92 Sedan. With a D15B7 in it...
The fuse that powers my cluster lights and tail lights, keeps blowing...
Anyone have an idea of where I can start first? PLEASE!!! I need help.
I've been pulled over 4 times already! HELP ME!!!!!
I would check to see that the fuse you originally pulled out was the correct amp. That would be the best place to start. Im not saying i doubt you... Im just saying to double check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidwit93delsol »</TD></TR><TR><TD CLASS="quote">I would check to see that the fuse you originally pulled out was the correct amp. That would be the best place to start. Im not saying i doubt you... Im just saying to double check.</TD></TR></TABLE>
if this isnt the case start checking grounds.
i had this same problem, it ended up being the ground. i took the guage cluster out and there is a ground connection in the dash on your right by the steering column. i just clipped the wire and reconnected it. are your gauge cluster light messing up too?
yeah, it's definitely a pain in the ***. but i had no clue what i was doing so i bought a haynes manual, and followed the electrical diagram. 2 hours later i fixed it and also put in a walbro fuel pump
Prob a bad ground somewhere, i would def check them.
Check the one on the tailgate,driver floor, underdash one
http://C:\Documents and Settin...ments
Alright. Here is the new problem!!! I went to a local tuner shop. They said its most likely the headlight switch is going bad. So I picked one up for $50. Pulled my steering wheel. And changed it out. Everything worked. Until I did a burn out one night at the races... Everything was working perfect. Got the tires warm. About mid burn out. The fuse blew. So it must be a ground problem, right?
dude, its a ground. 100% on this. and for the record.. never try to use a fuse higher than the original number, best way to continue to mess stuff up worse!
Use the recommended fuse, they put it in for a reason! And its not true, "oh the higher up you go, it just makes it harder to blow the fuse" thats so bad! i had a friend who told me that, and i honestly turned around and told him the never talk again.
YOU WERE SO RIGHT! Since I have a sedan. It was the drivers side marker light... Fixed it. And it hasn't popped again!
moyospeed
Nov 18, 2007 01:23 PM
b18civicHx
Apr 4, 2007 08:58 PM
1sikcoupe
10
May 7, 2004 03:23 PM
FBP Si 2000
Dec 23, 2003 05:16 PM
