oe clutch on turbo
Old Jan 10, 2008 | 07:00 PM
blackcherry's Avatar
Default oe clutch on turbo
i recently received my peakboost turbo kit and im pretty sure my car has a stock clutch (got it in october) anyways its a gsr and the clutch holds fine never slips and what not, but will it hold up with this kit? or will it just wear down really fast? ill be boostin with the wastgate no bc so the spring is at about 7lbs of boost.
Old Jan 10, 2008 | 07:26 PM
hotrod99's Avatar
Default Re: oe clutch on turbo (blackcherry)
your prob. going to want to start looking into buying an upgraded clutch soon if your going to be beating on the car.
Old Jan 10, 2008 | 07:51 PM
ekhonda87's Avatar
Default Re: oe clutch on turbo (hotrod99)
my stock clutch slipped as soon as i got into boost with my b16
Old Jan 10, 2008 | 08:15 PM
a1320honda's Avatar
Default Re: oe clutch on turbo (ekhonda87)
I had an OEM Type R clutch and flywheel on my teg N/A, and i put the boost to it and it lasted about 4 solid months of constant everyday abuse, But even at a lowly 10psi it started to go. Id say if your in a position....upgrade that clutch. Even if its with a cheap XTD clutch youll be better off.
Old Jan 11, 2008 | 07:58 AM
maxxd97's Avatar
Default Re: oe clutch on turbo (a1320honda)
Might as well upgrade the clutch now, the stock clutch will not hold up and you will just end up replacing it down the road.
Old Jan 11, 2008 | 08:14 AM
tegdude227's Avatar
i seen this in a movie once they dident make it
^ bad boys 2 quote
but really its only a matter of time some stock clutches go out na so you cant expect it to last boosted on and if you just got it in october you never no how they drove it before you better safe then sorry
Old Jan 11, 2008 | 12:28 PM
turbotypeR@SPEC's Avatar
25 Year Member
i can hook you up with a spec stage 3. it drives great and will hold the power no problem. pm me for more details
Old Jan 11, 2008 | 04:20 PM
i have an exedy but im getting ancy and want to turbo it soon instead of waiting and installing the clutch first
Old Jan 11, 2008 | 04:40 PM
93CX's Avatar
Default Re: (blackcherry)
You'll enjoy the car a lot more with an upgraded clutch
TurboTeg332
Feb 21, 2010 08:43 AM
SupaTeg
Aug 20, 2003 09:15 AM
MachAF
Mar 17, 2003 10:24 AM
MachAF
Mar 14, 2003 03:46 PM
01ITR#700
Oct 1, 2002 07:31 AM
