lost???
i am in the middle of my swap and the tranny that i got didnt come with a t bracket, i was wondering if i could use any 90-93 integra t bracket. it's a y1 tranny of the sir and its going into an 89 hatch
also using innovative mounts
thanx in advance
thanx in advance
if going into 89 hatch. The only T bracket that will fit is the 90-93 DA integra. The RS LS or GSR T brackets will fit perfect for your mounts. As for other years like 94- 01 it will not fit properly. I dunno why but to wide and narrower on the T handle. As for the axles use 90 -93 DA for your 89 hatch and same for clutch cable and throttle cable and half shaft and axles. Good luck
