clutch help?
Old Jan 10, 2008 | 01:46 PM
Dwalker's Avatar
Default clutch help?
hi just recently put a clutch in and the past two days it has made a click noise from the clutch when i release the clutch and pulling foward and when it is in nuetral it will not make the noise and today it quit doing it so what is the problem.
Old Jan 10, 2008 | 02:05 PM
VRD^sam's Avatar
Default Re: clutch help? (Dwalker)
Maybe you installed the Throw out bearing wrong, but i had almost the same problem.
Old Jan 10, 2008 | 04:03 PM
beast14's Avatar
i have the same problem on my dx
Old Jan 10, 2008 | 04:06 PM
pinky5's Avatar
Default Re: (beast14)
ya i had a friend with that problem.......making a noise when the clutch is out but when the clutch is in it would go away...pretty sketchy ide say
Old Jan 10, 2008 | 04:33 PM
Dwalker's Avatar
Default Re: (pinky5)
i'm pretty sure everything got put in right i had three people helping and i did everything by the book. It actually quit tonight and now it is fine i dont know whats going on hopefully somebody can give me an idea
Old Jan 11, 2008 | 06:21 AM
Dwalker's Avatar
Default Re: (Dwalker)
help
Old Jan 11, 2008 | 12:45 PM
speedooo's Avatar
if it maews noise when the clutch is disengaged the tob is bad-the throwout bearing is being pressed against the pressure plate
if it makes noise when the clutch is engage-input shaft bearing. the tob has no pressure on it when the clutch is engaged
John Vang
Aug 15, 2013 08:03 AM
nytosc
20
Aug 8, 2011 08:29 AM
cubanbear16
Jan 17, 2006 05:01 PM
jbsmith
Aug 29, 2005 12:21 AM
Tokyo_X-treme_Racer
18
Jan 28, 2004 11:48 AM
