LHD power window install....power window wiring rubber boots help
Old Jan 10, 2008 | 01:21 PM
alscrx's Avatar
Default LHD power window install....power window wiring rubber boots help
I am getting ready to install a edm power window kit and power door lock actuators i got from a friend. The original door to fender wire protector or sleeve is very small cause only 2 wires run through it for the speakers on usdm cars.
Did anyone get all the extra wires through the factory door jamb loom or did you have to switch it from another car.....
I heard the 4 door ex rubber looms will work but too hard to find.
Any suggestions or possible experience???
Stock crx wiring loom! Too small for more wires!!
This is the civic ex loom assuming from 88-91? Can anyone confirm this???
I borrowed these pics.
Modified by alscrx at 4:00 PM 1/11/2008
Old Jan 10, 2008 | 01:42 PM
RSZero1's Avatar
Default Re: LHD power window install....power window wiring rubber boots help (alscrx)
those look like pics from Wes V's website. He still has his instructions up for power windows and doorlocks LHD style.
i forget the address, but you should even be able to google it.
Old Jan 10, 2008 | 01:43 PM
black0hatch's Avatar
his site is in the faq too.
Old Jan 10, 2008 | 08:51 PM
alscrx's Avatar
Default Re: LHD power window install....power window wiring rubber boots help (black0hatch)
I am not asking how to do it, I borrowed the pics from his site. I asked if anyone else did it without hunting down those scarce 4 door ex door looms????
Old Jan 11, 2008 | 06:13 AM
bmg123's Avatar
I have installed EDM LHD power windows in my CRX too. It was a while ago, but if I remember correctly, I just bought some plastic tubing from a hardware store and sealed it up with some electric tape. I have some pics on my mini write up if you want to see.
https://honda-tech.com/zerothread?id=1704852
Old Jan 11, 2008 | 09:36 AM
alscrx's Avatar
Default Re: LHD power window install....power window wiring rubber boots help (bmg123)
Thanks, i didn't want to use the regular loom cause it will eventually crush and fall apart. I guess i will just have to keep searching for the 4 door loom and clips. Incase i have to remove the doors i don't need to cut all the wires
That will help with my wiring when i get to it
Old Jan 11, 2008 | 11:26 AM
Zaakro's Avatar
these are the plugs and by the way the holes where the loom goes through are the same size and use the same loom on the JDM EDM CDM UKDM and USDM just different plugs
Old Jan 11, 2008 | 11:42 AM
alscrx's Avatar
Default Re: LHD power window install....power window wiring rubber boots help (Zaakro)
How could they all use the same size diameter loom when they run different amount of wires? The jdm and ukdm run power windows and power mirrors while USDM runs 2 speaker wires.
Wes V pics shows a big difference in the civic 4 door loom and the crx loom.
i am looking for the complete loom as in the second pic
Old Jan 11, 2008 | 11:44 AM
Zaakro's Avatar
what i was talking about is the boots are all the same
driver side harness
Old Jan 11, 2008 | 11:52 AM
alscrx's Avatar
oh ok, yeah i figured the boots were the same cause they are made around the same years....
So to make it a factory conversion, i need both door harness clips and both chases clips. I can reuse my factory boots and find a thick rubber piece from home depot and i will have a thicker loom.
Can anyone help out with sourcing the 4 clips i need. They must have pigtails please.....
Old Jan 11, 2008 | 12:02 PM
alscrx's Avatar
If that harness is from a EF9 then will it work on the USDM left door with LHD edm door switches??
Old Jan 11, 2008 | 12:21 PM
Zaakro's Avatar
yes they are the exact same harness but only thing the JDM one has over the edm is JDM power windows have auto up and down well EDM have only down
Old Jan 11, 2008 | 12:41 PM
alscrx's Avatar
wow i didn't know that so there are extra wires for the auto up in the harness??
Geryha
May 19, 2018 09:34 AM
imonx850
Dec 5, 2010 08:22 PM
h22acd5
Dec 28, 2008 02:21 PM
civicsir94
Feb 10, 2005 01:08 PM
Mikeman191
Apr 18, 2004 06:50 PM
