lsvtec would a bigger oil line to head be better
Ok i had a lsvtec put in my car and had the sandwhich adaptar but it leaked for some reason. So i got a new kit from whitfield racing but the hose looks so small like a line u would use on a turbo like the oil feedline or something. Not sure the size but is there a difference in performance or anything by getting a bigger one like the golden eagle steel braided line?
From: gravity rides everything...everything will fall, se GA/ne FL
use -4 and up. vtec won't see enough pressure to turn on with a -3 turbo feed line.
Ive used a -3an line for over a year now with no problems. I inspect my cams and see no abnormal wear and have no oil pressure loss a x-over.
With a -4an line and bigger (which many people use with no problems), I can see it making the oil pump work a bit harder to supply the added oil. Correct me if I'm wrong.
hmm ok, i mentioned don't use -3 because i personally tried to. i had to go over everything when vtec wouldn't come on with zero cel's and plenty of oil. turns out it worked fine after i changed the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic »</TD></TR><TR><TD CLASS="quote">hmm ok, i mentioned don't use -3 because i personally tried to. i had to go over everything when vtec wouldn't come on with zero cel's and plenty of oil. turns out it worked fine after i changed the line. </TD></TR></TABLE>
what size did you go to??
i just use -4. about -3 working i guess it does then. maybe there is more too it like length, which oil pump you use maybe. forget what i say then about it.
sampol999
Sep 3, 2006 01:09 PM
RuthlessEF-9
Nov 29, 2002 02:29 PM
