JDM Speed limiter question.
Old Jun 30, 2002 | 10:04 AM
TriniR's Avatar
Default JDM Speed limiter question.
I have a 1998 JDM Type R which is bone stock and as a result has the speed limiter intact. It kicks in at an indicated 200 kmph (124 mph) - although the speedometer only has markings up to 190 kmph. (is it possible to get a 240 kmph speedo and can adjusted to the current mileage ?)
I would like to know what are my options for removing this limiter. I noticed that HondaData sells a stage 1 ecu but there are not many details about it. Is this a straight swap deal or would i have to send my ecu somewhere to get the restriction removed. Are there any other options ?
I don't know much about this so any assistance would be appreciated.
Thanks.
Old Jun 30, 2002 | 10:29 AM
mugenracer's Avatar
Default Re: JDM Speed limiter question. (TriniR)
Blitz plus many other companies make a speed de-limiter which attaches between the speed sensor wire and the ecu, theyre relatively simple to fit and cost arrond $100
http://www.blitz-uk.co.uk/
I have a JDM integra Si and bought an R Spec vtec controller off ebay for $130 which removed the limiter.
[Modified by mugenracer, 11:29 AM 6/30/2002]
Old Jun 30, 2002 | 11:50 AM
underrated99si's Avatar
Default Re: JDM Speed limiter question. (mugenracer)
Hahahhah I can got 140+ JK you could always get a US spec ECU
Old Jun 30, 2002 | 11:58 AM
GokuSSJ4's Avatar
in other for you to install hondata you have to be OBD1 or run a jumper ,
and if thats the case just to remove the speed limiter just get an obd1 ecu and re-program it ..
Old Jun 30, 2002 | 12:19 PM
TriniR's Avatar
Default Re: JDM Speed limiter question. (Spoon1)
How can i tell if i have a OBD1 or 2 ecu ? I have wondered about this but i don't know how to go about finding this out.
Old Jun 30, 2002 | 12:29 PM
Keane Rated R's Avatar
I thought that JDM ITR´s had the same speedo as the euro spec? 270kmh
Old Jul 1, 2002 | 01:35 AM
DutchITR1689's Avatar
Default Re: JDM Speed limiter question. (Integra Rated R)
Nope. They all go to 180 km/h plus one notch.
[Modified by DutchITR1689, 1:16 PM 7/1/2002]
Old Jul 1, 2002 | 02:30 AM
pho king guy's Avatar
Default Re: JDM Speed limiter question. (DutchITR1689)
have any of you hit 8400 rpm with it dumped out the headers? very loud... very loud indeed.
SupamaN8832
Jun 28, 2004 06:12 AM
B18C-Hatch
Oct 14, 2002 10:38 AM
topher
Jan 28, 2002 06:45 PM
Maxime
Oct 31, 2001 06:35 PM
