Can i rebuild the engine while it is still attached to the car?
Old Jan 10, 2008 | 11:11 AM
Powered by VTEC's Avatar
Default Can i rebuild the engine while it is still attached to the car?
Can i rebuild the engine while it is still attached to the car? just some pistons upgrade and cams, timing belt and water pump.
or i have to take the whole engine out ? thanks
Old Jan 10, 2008 | 11:37 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Can i rebuild the engine while it is still attached to the car? (Powered by VTEC)
Yes it can be done.
You can replace rod bearings, pistons, rings, do a surface hone on cylinder walls, rebuild the head (once removed of course) all while the engine is still in the car.
Hell the techs at my shop have also done main bearings while then engine was still in the car.
Belts and waterpump jobs are done daily here at my shop without coming close to remove the engine.
Old Jan 10, 2008 | 11:38 AM
pdiggitydogg's Avatar
how the hell do you do main bearings with the block in the car?
Old Jan 10, 2008 | 11:41 AM
93egSLEEPER's Avatar
Default Re: (pdiggitydogg)
it CAN be done but wouldnt be my first choice for working on a bottom end. i want to be able to get that part of the motor done where i can see well and i wont have any second thoughts on how well i did it upside down. as for cams and head work that is done with the motor in the car more often then not.
Old Jan 10, 2008 | 12:11 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (93egSLEEPER)
ever watch omnimans build?
Old Jan 10, 2008 | 12:18 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">how the hell do you do main bearings with the block in the car?</TD></TR></TABLE>
Spin the crankshaft over. It requires finesse.
I personally would not do it, but sometimes mechanics do stuff just to prove it can be done. Boredom and the ability to say "I told you so" is amazing sometimes.
Old Jan 10, 2008 | 12:37 PM
Boostfed86's Avatar
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
I personally would not do it, but sometimes mechanics do stuff just to prove it can be done. Boredom and the ability to say "I told you so" is amazing sometimes.</TD></TR></TABLE>
That and its soo damn nice to get paid for a motor R&R when you don't have to take it out!!!
Old Jan 10, 2008 | 12:48 PM
Cza_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote"> Boredom and the ability to say "I told you so" is amazing sometimes.</TD></TR></TABLE>
Very true.
Old Jan 11, 2008 | 11:09 AM
vestalfootball72
Guest
Posts: n/a
Default Re: (Boostfed86)
When my father was a mechanic he said he would never pull a engine to rebuild, unless it needed a rebore- Saves much time, and is simpler-
Old Jan 11, 2008 | 12:40 PM
MoreBoost!'s Avatar
Default Re: (vestalfootball72)
i done it with out pulling the engine but to me it would be easier if u pull it out
kinkyintegra
Jan 12, 2007 04:40 AM
Sam92Teg
May 27, 2005 06:35 PM
92integraVTECgsr
Jan 11, 2005 12:28 PM
the DA in HONDA
Jun 29, 2004 07:48 PM
