NEED HELP ASAP!!! Valve Cover Prob
Old Jan 10, 2008 | 08:52 AM
rebar71's Avatar
Default NEED HELP ASAP!!! Valve Cover Prob
OK - so I had a small seep in the front of my engine - stock B18B - coming from the valve cover. So I pulled it off to check the seal.
Seal looked good so I put it back on... NOW I HAVE OIL LEAKING INTO WHERE THE SPARK PLUGS CONNECT TO THE WIRES!!! BAD!!!
HELP!!! ASAP!!!
Old Jan 10, 2008 | 08:55 AM
rocketrex's Avatar
dont start it again! goto honda and get a replacement valve cover gastet and get new seals that go around the spark plugs!!! also get some gasket sealer.....ur going to spend about 30 ish bucks but your not going to regret it.
Old Jan 10, 2008 | 09:04 AM
rebar71's Avatar
Default Re: (rocketrex)
What's the best way to get the oil out that is in there?
Old Jan 10, 2008 | 09:21 AM
rocketrex's Avatar
shoot i say really a solf cloth or paper towels.....u have to be careful when u do this otherwise u leave **** behind and it'll never start.
Old Jan 10, 2008 | 09:24 AM
rebar71's Avatar
ok - that's what I'm doing...
Thanks.
Old Jan 10, 2008 | 09:26 AM
rocketrex's Avatar
and clean the plugs...or if u got the cash replace them
Old Jan 10, 2008 | 01:41 PM
fadedgsr's Avatar
Old Jan 10, 2008 | 03:10 PM
MrDomino's Avatar
Default Re: (fadedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebar71 &raquo;</TD></TR><TR><TD CLASS="quote">What's the best way to get the oil out that is in there?
lol, did anyone see the top gear episode (it's the newest season, 10) where James says he uses tampons to soak up oil?
Old Jan 10, 2008 | 04:25 PM
rebar71's Avatar
Default Re: (MrDomino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDomino &raquo;</TD></TR><TR><TD CLASS="quote">
lol, did anyone see the top gear episode (it's the newest season, 10) where James says he uses tampons to soak up oil?</TD></TR></TABLE>
LMAO - I shoulda thought of that. As it is, I soaked it up with the paper towel method.
Valve cover is back on with new seals. I will wait for morning to fire it up - gonna wait for the RTV liquid gasket to set good first. Don't want that crap floating around in my engine.
This whole thing started cuz I could smell a tinge of burnt oil in the cabin when coming to a stop after driving a few miles on the freeway. Just a small seep most people probably would've just lived with.
Thanks for the quick responses. TI wouldn't even allow my post. SEARCH... blah blah blah. I did search - and NOTHING. Frakkin' *****. I get a lot of good info from there without having to post, but the SEARCH function is not the end-all be-all for getting answers.
Modified by rebar71 at 5:45 PM 1/10/2008
Modified by rebar71 at 5:46 PM 1/10/2008
Old Jan 10, 2008 | 04:51 PM
CubanLynx84's Avatar
Default Re: (rebar71)
welcome to anti ti club!!!!! all of us have experienced the ****'s over there. any by any chance being that you had the valve cover off did you change the cam seal cause that most likely is the leak you had. The notorious cam seal leak from honda.
Old Jan 10, 2008 | 05:00 PM
rebar71's Avatar
Default Re: (CubanLynx84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CubanLynx84 &raquo;</TD></TR><TR><TD CLASS="quote">any by any chance being that you had the valve cover off did you change the cam seal cause that most likely is the leak you had. The notorious cam seal leak from honda.</TD></TR></TABLE>
No - the cam seal was fine. The initial leak was def from the the front of the head/cover seal - toward the driver side.
Old Jan 10, 2008 | 05:46 PM
scottland221's Avatar
maybe one of the spark plug seals fell off. Make sure you check them, i have never had to replace mine. But they do say to replace the valve cover gasket everytime you take it off. The best way to get the oil out is get and extractor, with a small tube and suck it out. You could go to like a valvoline or some place that has a T tech machine and those have a line with a real small hose. That owuld work good to.
Old Jan 10, 2008 | 08:24 PM
teg_95's Avatar
Default Re: (scottland221)
i ad that problem with oil getting into cylinder 2. got new valve gasket, and spark plug seals. how i got the oil out. take your spark plugs out. get a air gun. wrap it with a cloth, stick it in the cylinders and shoot it out. the cloth will catch it. just dont cover the whole where the air comes out the gun. when you do this you car will burn a little bit of oil for a bout five minutes.
Old Jan 12, 2008 | 05:55 AM
!!JDMBUTTMUNCH!!'s Avatar
Replace the plugs or clen them with a lil gasoline then undo the bolts on the intake manifold and do them in a sequnce like
1 5
Old Jan 12, 2008 | 08:44 AM
rebar71's Avatar
Default Re: (!!JDMASSF*CK!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by !!JDMASSF*CK!! &raquo;</TD></TR><TR><TD CLASS="quote"> undo the bolts on the intake manifold and do them in a sequnce like
1 5
Why would I do that? Seriously.
It's already back together and running great with no leaks. What I still need to do is get some engine degreaser and clean up the mess.
Old Jan 12, 2008 | 10:18 AM
rocketrex's Avatar
just dont worry about doing that man. I had the same problem and after doing that it went away....just go have fun with ur car!!
Old Mar 12, 2009 | 10:38 AM
acnate2323's Avatar
New User
Default Re: NEED HELP ASAP!!! Valve Cover Prob
Yes I have question as well about my valve cover gasket. I have replaced it many times and the front corner keep leaking. I have trying no sealant and sealant on the corners. The two humps on each side are fine its just in the corner what can i do.
Old Mar 12, 2009 | 11:16 AM
rebar71's Avatar
are you sure it's not a leaking the cam end plug?
Old Mar 12, 2009 | 11:24 AM
acnate2323's Avatar
New User
well i think so i will watch it the next couple days but i pretty sure its the two front corners that are leaking.
Old Mar 12, 2009 | 11:30 AM
rebar71's Avatar
Make sure you clean it up real good.
clean engine = easy to find source of leaks
dirty engine = damn near impossible
Old Mar 12, 2009 | 11:44 AM
acnate2323's Avatar
New User
well i use a soft clothing to clean all oil off is there some type of cleaner i can get to make sure it is really clean
Old Mar 12, 2009 | 11:56 AM
rebar71's Avatar
Just pick up some engine degreaser from your local auto parts store.
When you use it, cover things (dizzy, battery, fuse box, throttle body) up with plastic bags - the other miscellaneous sensors can handle a bit of water. You want to have the engine slightly warm - the degreaser works better that way. Spray the stuff all over and let it sit for about 5-10 minutes. Then hose it down. Area's with heavy build-up may require some scrubbing.
It's worth your time to do this. Not only will it help you track down the source of your leak, but a clean engine is nice to look at too.
Old Mar 12, 2009 | 12:21 PM
acnate2323's Avatar
New User
ok thats sounds good but i just want something that will clean the valve cover gasket and and the gasket sits on to make sure it got a clean seal. I do not care at this point if the engine is clean just that it seals. and i know where is leaks so i will clean it here then see what i got.
Old Mar 12, 2009 | 12:52 PM
rebar71's Avatar
Do what you want then. All I'm saying is that with a dirty engine, you can't even be sure 100% where your leak is coming from. There many places the head can leak and the evidence can be misleading. You say you've already replaced the VC gasket multiple times, but it still leaks. OK - either your head is warped or it's not really leaking from where you think it is.
OrangeTeggy
May 16, 2009 08:28 AM
standbackimapro
Apr 29, 2006 05:38 PM
DrewQ1
Nov 21, 2004 10:36 PM
05 600RR
Jan 25, 2004 12:50 PM
elpermgrande
Oct 18, 2002 04:42 PM
