XR80 runs terrible, Can anyone help ?
Old Jan 10, 2008 | 04:04 AM
bbbobbb's Avatar
Default XR80 runs terrible, Can anyone help ?
My son owns a 1985 XR80 and runs terrible. I replaced the rings because of the black plug and smoking exhaust (its a 4 stroke)
Can the timing be adjusted ? My be the jets replaced? I'm getting frustrated into why it wont idle smoothly. Can anyone help ? Thanks for reading. Bob
Old Jan 10, 2008 | 04:33 AM
fatboy01's Avatar
Default Re: XR80 runs terrible, Can anyone help ? (bbbobbb)
Did you clean the carb and check the spark plug? If so, try adjusting the pilot screw to get a smoother idle. Fresh gas may also help.
Old Jan 10, 2008 | 05:47 AM
MSchu's Avatar
My Name is Nobody
when replacing the rings did you hone the cylinders? what year XR? are you sure your timing is correct(eg chain/tooth position)? ws ti running proper prior to you opening it up and doing the rings?
Old Jan 10, 2008 | 06:19 AM
unusual71's Avatar
check the ignition points my XR80 needed them cleaned all the time but it was a bit older so i do now know, but a guess anyways.
Old Jan 10, 2008 | 06:41 AM
MSchu's Avatar
My Name is Nobody
Default Re: (unusual71)
For sure... if its a points system your going to get sh*tty running if the gap is not correct. but one step at a time
Old Jan 10, 2008 | 07:10 AM
newby_j's Avatar
Needs More Cowbell
Default Re: (MSchu)
valves need adjusted?
Old Jan 10, 2008 | 07:51 AM
bbbobbb's Avatar
Sounds like all good stuff to check. The cylinder was honed, new spark plug, I had to get the timing chain back in position. My bigger question is the timing. Can the timing be off by a link or two positions ? How do you adjust for timing ?
Old Jan 10, 2008 | 08:21 AM
MSchu's Avatar
My Name is Nobody
yes you can be off... you can be off by a tooth +/- or you can be off by 180 degrees. I mean to be honest I dont have hands on experience with an xr, but I do know about mechanical issues. Also if the bike is already together, check points gap and points condition before removing the valve cover to look at tooth position. Have you cleaned the fuel system (lines, filter, carbs)?
Old Jan 10, 2008 | 08:31 AM
bbbobbb's Avatar
Yes, I cleaned the carb. I know the timing is close and not off 180 degrees. Also I'm using new gas. And yes it ran the same way before I changed the rings. How can the timing be slightly adjusted ?
Old Jan 10, 2008 | 08:34 AM
MSchu's Avatar
My Name is Nobody
on the xr I am not sure about the cams... but usually it's on or it's off, unless you have adjustible gear up there... other than that the gap/rotation issue at the points is the only other method of control. is your cam chain tension adjusted properly?
Old Jan 11, 2008 | 03:00 AM
ktmoffroad72901's Avatar
ya might wanna check your cam chain for stretch as well as your valves, seats, and guides.
the cam chains really like to stretch, and the guides and valves like to get loose and leak.
look at your cam lobes for gaulding, and check your valve springs for pressure and make sure theyre not broken.
might perform a leak down test and save yourself some diagnostic time.
thumpertalk.com, xrsonly.com are a couple good sources for info....service manual and such.
hope this helps.
by the way im lookin for a 70-90 xr/crf block if anyone has one cheap.
Old Jan 11, 2008 | 05:26 AM
MSchu's Avatar
My Name is Nobody
Default Re: (ktmoffroad72901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ktmoffroad72901 &raquo;</TD></TR><TR><TD CLASS="quote"> ya might wanna check your cam chain for stretch as well as your valves, seats, and guides.
hope this helps.
by the way im lookin for a 70-90 xr/crf block if anyone has one cheap.</TD></TR></TABLE>
b18b1Ej
Aug 19, 2013 11:50 PM
b18b1Ej
Aug 19, 2013 02:52 PM
srt4pilot
33
Jun 22, 2009 09:36 PM
efjones9
May 14, 2009 08:45 PM
zCivic
Jun 22, 2006 02:06 PM
