oil in spark plugs
Old Jan 9, 2008 | 10:47 PM
Sycosis's Avatar
Default oil in spark plugs
well i may sound stupid...since i dont know much about these things. i would just like to know if someone could let me know what it means when you find youre spark plugs basically swimming in oil. any help would be appreciated. its a 91 civic hatch with what a SOHC motor.
Old Jan 9, 2008 | 11:11 PM
STREETWERKZ's Avatar
Default Re: oil in spark plugs (Sycosis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sycosis &raquo;</TD></TR><TR><TD CLASS="quote">well i may sound stupid...since i dont know much about these things. i would just like to know if someone could let me know what it means when you find youre spark plugs basically swimming in oil. any help would be appreciated. its a 91 civic hatch with what a SOHC motor. </TD></TR></TABLE>
That's not stupid. If you arent familiar with these cars, you could probably think something major is wrong with it. You have a legitimate question.
Look into a spark plug tube seal replacement. Better yet, buy these gaskets from your local dealership.
<FONT SIZE="2">#2 and #3 in this illustration.
#17 and #18 in this illustration.</FONT>
Old Jan 10, 2008 | 09:38 AM
twiztid17thninja's Avatar
Default Re: oil in spark plugs (STREETWERKZ)
agreed you also might want to get a tube of hondabond while you are at it use just a little on either side of the seals and you could probably also stand to replace the valve cover gasket while you are in there.
Old Jan 10, 2008 | 11:47 AM
S_O_H_C_crx's Avatar
could be headgasket....that happend 2 me when my head gasket went bad
Old Jan 10, 2008 | 12:19 PM
GSX 4G63T's Avatar
Oil in spark plug. Somehow oil is seeping through the seals. but which one?? That is the question...I first would check the spark plug grommets then move on to the valve seats/ guides. If possible rebuild the head with new seals to be on the safe side
Old Jan 10, 2008 | 12:22 PM
import2nr88's Avatar
As STREETWERKZ said... If there is oil in spark plug tubes (the area where the plug wires go) then the tube gaskets are bad.
They are fairly inexpensive just pick up a valve cover gasket allong with the spark plug tube gaskets and a tube of hondabond (to use on the 4 corners where the valve cover gasket meets the cam humps.)
Old Jan 10, 2008 | 05:25 PM
Default Re: (import2nr88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import2nr88 &raquo;</TD></TR><TR><TD CLASS="quote">As STREETWERKZ said... </TD></TR></TABLE>
yes, my answer is correct. when i worked for honda, i sold a set of those a day. im positive that the parts i showed are the ones he needs.
Old Jan 10, 2008 | 06:30 PM
lsvtec hf's Avatar
Default Re: (STREETWERKZ)
Maybe lots of blow-by (oil passing the piston rings)? Does it smoke real bad? Blue smoke
Old Jan 10, 2008 | 07:17 PM
IMALLSLO's Avatar
The easy fix is gonna be the spark plug grommets. Replace those first and a valve cover gasket at the same time. If it continues,then you need to replace the rocker seals(#17 on the diagram). There are four rubber seals between the rocker arms and the head. They tend to leak oil into the spark plug tibes over time as well. They are fairly inexpensive but is a little more in depth in the repair.
Edit: Just saw Streetwerks already pointed out the rocker seals
Old Jan 13, 2008 | 09:02 AM
Default Re: oil in spark plugs (IMALLSLO)
i am really glad to see that this thread went on so long. the question was answered correctly by the first post and yet we went on to see 7 more posts congrats thank you for reading the previous posts.
Old Jan 13, 2008 | 09:12 AM
SIred91's Avatar
Rainman
Default Re: oil in spark plugs (twiztid17thninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid17thninja &raquo;</TD></TR><TR><TD CLASS="quote">i am really glad to see that this thread went on so long. the question was answered correctly by the first post and yet we went on to see 7 more posts congrats thank you for reading the previous posts.</TD></TR></TABLE>
Lets all unnecessarily quote streetwerkz over and over just to say the same thing 10 times...hahaha.....this place cracks me up.
Old Jan 13, 2008 | 09:26 AM
Default Re: oil in spark plugs (SIred91)
sometimes i wonder if people even bother to read the first two posts before they say something there could be 500000000000 posts and the question was answered on the first post and people will still say well you need to blah blah blah; ahh good times
Old Jan 13, 2008 | 09:48 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Lets all unnecessarily quote streetwerkz over and over just to say the same thing 10 times...hahaha.....this place cracks me up. </TD></TR></TABLE>
Yes, what STREETWERKZ said.
We all know this place is full of a bunch of coat-tail riders who give "x2" and "" posts to get their count up.
Old Jan 13, 2008 | 09:55 AM
Tippyman's Avatar
Default Re: oil in spark plugs (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
We all know this place is full of a bunch of coat-tail riders who give "x2" and "" posts to get their count up.</TD></TR></TABLE>
x2
Old Jan 13, 2008 | 09:58 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: oil in spark plugs (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
x2 </TD></TR></TABLE>
LOLZ ur kewl y0.
Old Jan 13, 2008 | 10:00 AM
Tippyman's Avatar
Haha, I had too.
BTW: I think this thread can safely be locked now.
Old Jan 13, 2008 | 10:20 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Haha, I had too.
BTW: I think this thread can safely be locked now.</TD></TR></TABLE>
x2.......... 's
Old Jan 13, 2008 | 10:22 AM
yeah... what tippyman said.
x2.
Old Jan 13, 2008 | 10:25 AM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">yeah... what tippyman said.
x2. </TD></TR></TABLE>
UhUhuu....I said it first.....x2
Old Jan 13, 2008 | 10:29 AM
damn, you're fast!
Old Jan 13, 2008 | 10:34 AM
SIred91's Avatar
Rainman
Im so fast......Ya'll know I live one quarter mile at a time.....
Old Jan 13, 2008 | 08:23 PM
LatnKng's Avatar
Im so fast......Ya'll know I live one quarter mile at a time..... </TD></TR></TABLE>
LoL...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">
If Im not mistaken, i believe that the gaskets will run you about 16 dollars plus tax from your local honda dealership..thats the valve cover gasket and spark plugs seals.
i-VTEC_DOHC
Honda Civic (2006 - 2015)
11
Apr 5, 2008 09:51 PM
sedlmeier101
Sep 4, 2007 09:15 AM
Midori Green
15
May 25, 2007 12:39 PM
tomster
Aug 29, 2006 02:11 PM
Kevin Cliff
Apr 25, 2004 06:37 PM
