5th. Gen 'Lude Tire Questions
Old Jun 30, 2002 | 08:35 AM
rlumd's Avatar
Default 5th. Gen 'Lude Tire Questions
Since the stock RE-92s are spinning and slipping in the wet, I am looking into replacing them. However, the stock size (205/50/16) seems to have limited selections for all-season tires (I don't have the budget for 2 sets of tires). My questions:
1. Can I use 205/55/16? Since that size has a lot more choices than the stock size.
2. What effects would I see on my odometer and speedometer if I go with the higher profile tires?
3. What will the 55-series tires affect the 'Lude's handling?
Your help is appreciated.
Old Jun 30, 2002 | 04:51 PM
TypeSH's Avatar
Default Re: 5th. Gen 'Lude Tire Questions (rlumd)
Yea you can use a non-stock tire size if it fits on the tire/car w/o any issues.
Larger than stock tire would mean you are travelling faster than what your speedometer/odometer is reporting. It isn't a huge difference thou, very minute.
I would guess that ride quality should be generally better since there's more sidewall, but handling might be slightly reduced w/ more sidewall to flex.
Old Jul 1, 2002 | 05:24 AM
tec-9-7's Avatar
Your acceleration will be slightly diminished due to the effective reduction in final drive ratio - conversely, your fuel economy ought to rise by the same small percentage...
Paul
Old Jul 1, 2002 | 02:22 PM
rlumd's Avatar
Default Re: 5th. Gen 'Lude Tire Questions (Mr. NiceGuy)
Thanks guys. I'll see what kind of tires I'd buy in the larger size. I mean, the stock size is full of performance tires with very limited selection of all-season ones. I'd like to have a set of S-03 PP with another set of winter tires, but $$$ doesn't allow for that.
Thanks for the answers!
jdmitrdc2
Mar 18, 2009 12:49 PM
HooTeNannY
Nov 15, 2008 03:11 PM
honda_andy
Oct 12, 2006 09:45 PM
boostedsol
Oct 15, 2003 01:44 PM
97LudeSH
Oct 25, 2001 12:32 PM
