GSR or OEM???
Old Jan 9, 2008 | 07:17 PM
jjipson's Avatar
Default GSR or OEM???
I have a b18b1 out of a 1994 Integra Ls. I am rebuilding the motor and in the future I plan to run about 15 lbs of boost. Wich rebuild is more inviting to psi. By the way its going into my 5th gen civic
Old Jan 9, 2008 | 07:38 PM
PrinceAli132's Avatar
Default Re: GSR or OEM??? (jjipson)
If built right both setups will run well.
However the LS/V will cost more money. Personally, I'll take the extra money from the LS/V and put it toward other items in your build/project.
Ali
Old Jan 9, 2008 | 07:46 PM
Schister66's Avatar
Man U FTW
What's your power goal? PSI is irrelevant...once you tell us that AND the fuel you plan to use, we can accurately answer your question.
Old Jan 10, 2008 | 01:19 PM
jjipson's Avatar
Default Re: (Schister66)
I really want to get 250+ hp with the turbo. I just want to run pump gas. supreme probably. that is what I run anyway.
Old Jan 10, 2008 | 01:26 PM
Schister66's Avatar
Man U FTW
Either engine will do that with relative ease. I can tell you from experience that GSRs love boost and will handle quite a bit more than what you're looking for on the stock block. The numbers in my sig are on the stock GSR block...the FS link has my dyno graph if you want to see just how streetable it can be.
peacemaker
Oct 25, 2007 02:22 PM
Ilove theDA
Nov 4, 2006 03:05 PM
brad17
May 18, 2005 07:53 PM
HT Username
15
Mar 9, 2005 05:15 PM
integralsdriver29
Jan 20, 2005 07:59 PM
