Skunk2 Lowering Springs Chart
I don't understand why it has two spring rates each for the front and the rear. It says Front Rate Tender/Main and Rear Rate Tender/Main. What's the difference of the tender and main spring rate? Here's the chart in case you're wondering what I'm talking about....
http://www.skunk2.com/images/s...g.gif
A dual-spring setup is similar to using a single progressive spring. The tender spring and the main spring compress together to give a softer initial rate until the tender binds, at which point the main spring takes over completely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smash03 »</TD></TR><TR><TD CLASS="quote">Hmm....I see. So how would you calculate the spring rate as a whole?</TD></TR></TABLE>
Whenever I attempt to, smoke starts pouring from my ears.
I have no idea.
I have no idea.
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
bad-monkey
Aug 24, 2004 05:24 PM
