* * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * *
Old Jan 9, 2008 | 04:34 PM
DC2_8.2K's Avatar
Default * * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * *
Ok. My question, is MAINLY just to H2B Owners, as I want THEIR input on this. I'm thinking about doing a H2B swap for my civic. (Hurray!) I can get the whole swap (motor, b16 tranny, h2b kit, mounts, etc) for $2700. Like that topic says, what ECU/Piggyback system are you guys using? I'm thinking about getting the Apexi V-tec Controller for now and later upgrade to a S200. But I was wondering, my EX has a P28 already, who or how can I get it chipped? How much is it for a "chipped" P28? If I get a chipped p28, then do I still need the Apexi controller? Also, is the EG H2B kit usable on a EK model? Thank you for any information, much appreciated!
Old Jan 9, 2008 | 05:18 PM
chris1741's Avatar
Default Re: * * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * * (just_hatched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just_hatched &raquo;</TD></TR><TR><TD CLASS="quote">Ok. My question, is MAINLY just to H2B Owners, as I want THEIR input on this. I'm thinking about doing a H2B swap for my civic. (Hurray!) I can get the whole swap (motor, b16 tranny, h2b kit, mounts, etc) for $2700. Like that topic says, what ECU/Piggyback system are you guys using? I'm thinking about getting the Apexi V-tec Controller for now and later upgrade to a S200. But I was wondering, my EX has a P28 already, who or how can I get it chipped? How much is it for a "chipped" P28? If I get a chipped p28, then do I still need the Apexi controller? Also, is the EG H2B kit usable on a EK model? Thank you for any information, much appreciated!</TD></TR></TABLE>
definetely just keep your ecu and have it tuned on one of the many programs out there (hondata, crome, ecutune, etc.). No need at all to buy a POS vtec controller. For the money you are going to spend on it, even used, you can have your ecu chipped and at least street tuned on crome. Far better results.
Also, having a b tranny, as opposed to an H tranny, tuning wise makes no difference at all. your tuning the engines fuel curve and timing, nothing to do with the transmission.
Old Jan 9, 2008 | 05:44 PM
2fastGSR's Avatar
King of the One Liners
Default Re: * * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * * (chris1741)
I used a p28 , and tuned with ECtune. You can really use any management system you would like.
Check out phearable.net - you can purchase a p28 - chipped already with an H basemap and you will be set.
No real need for the vtec controller if you do the above.
Old Jan 9, 2008 | 08:08 PM
DC2_8.2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris1741 &raquo;</TD></TR><TR><TD CLASS="quote">
Also, having a b tranny, as opposed to an H tranny, tuning wise makes no difference at all. your tuning the engines fuel curve and timing, nothing to do with the transmission.</TD></TR></TABLE>
Thanks for your input. ecutune? Never heard of that one yet. Maybe have to do some research on that. If you guys recommend those over the Apexi controller, than maybe I'll reconsider it. If i was to choose, Hondata wins my vote. As for the type, how about the S100? Or should I spend a hundred dollars more for the S200?
Old Jan 9, 2008 | 08:09 PM
DC2_8.2K's Avatar
Default Re: * * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * * (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">I used a p28 , and tuned with ECtune. You can really use any management system you would like.
No real need for the vtec controller if you do the above.</TD></TR></TABLE>
Thanks for your input! I'll for sure check out that website!
Old Jan 9, 2008 | 08:27 PM
Chris Tune's Avatar
my mind...
Old Jan 9, 2008 | 08:36 PM
vinuneuro's Avatar
What does the transmission have to do with what you use to tune the engine?
Old Jan 9, 2008 | 09:01 PM
DC2_8.2K's Avatar
Default Re: * * *To ALL H2B Owners!!! What do you guys use to tune your swap?* * * (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">What does the transmission have to do with what you use to tune the engine?</TD></TR></TABLE>
Good question. Ask chris1741.
Old Jan 9, 2008 | 09:10 PM
chris1741's Avatar
Good question. Ask chris1741. </TD></TR></TABLE>
Dont ask me, ask YOU. why would u adress it to just h2b owners?? your just asking a basic question about engine management.
EDIT: And i'm drunk and an idiot so if i missunderstood u your probably right!!
Modified by chris1741 at 3:24 AM 1/10/2008
Old Jan 9, 2008 | 10:03 PM
DC2_8.2K's Avatar
Modified by chris1741 at 3:24 AM 1/10/2008</TD></TR></TABLE>
I'm asking this to H2B owners because I want their input, as what they're using to tune their swap. Correct me if I'm wrong, a b-series tranny can handle a higher rev rpm vs the h-series tranny. So with that in mind, tuning depending on the tranny, is something to look at also.
Chris Tune's Avatar
h2b or no h2b is the same ****... its still an H22 regardless of the tranny.
Old Jan 9, 2008 | 10:43 PM
DailyDrivenEJ1's Avatar
Eg kit and EK kit are different. Im using hondata s200 on a chipped p28.
Old Jan 10, 2008 | 12:31 AM
Billy_Bob's Avatar
Default Re: (DailyDrivenEJ1)
any of the obd1 editors will work. Depends on if you want super duper features you will proably never understand nor use
Neptune or crome
EF_monster
Nov 23, 2008 06:44 PM
tunerboy90
Sep 7, 2008 09:50 PM
grandam
May 16, 2007 08:03 PM
racingant
Jul 15, 2005 07:04 PM
hahagasdcrx
Aug 18, 2004 11:54 AM
