Lighting HID/Xenon kits, Retrofits and Associated Topics
wich hid kit did you use for you retro fit??
Old Jan 9, 2008 | 03:57 PM
SiR Inspired ED7's Avatar
Default wich hid kit did you use for you retro fit??
im doing a retrofit on my 89 civic useing zc headlights and s2k projecters but im not sure witch hid kit to go with
those who are expirienced on hid kit chime in
witch brands have you guys expirienced?? how much do s2k put out?? from what i know 4300k am i correct
Old Jan 10, 2008 | 11:36 AM
prelude1897's Avatar
Default Re: wich hid kit did you use for you retro fit?? (SiR Inspired ED7)
S2K are some of the best single xenon projectors to use for a retrofit. As for the HID kit to use, I always use OEM kits when doing retrofits for people. Any type of ballast that is equipped to power up D2S bulbs will work just fine
Old Jan 10, 2008 | 12:16 PM
doubleshotz's Avatar
Default Re: wich hid kit did you use for you retro fit?? (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">S2K are some of the best single xenon projectors to use for a retrofit. </TD></TR></TABLE>
Yup, my personal favorite single xenon projector.
I don't understand what you mean by 'kit'
If you're talking about output of bulbs, you want to pick out bulbs that have the highest lumen(lm) ratings. Kelvins(k) measure the color temepture and lumens measure the distance of light output. Higher the kelvin, lower the lumen almost everytime.
For example,
if you pick up Philips Ultinons (6000k), you'll loose about 500-700lm compared to OEM standard 4000-4300k bulbs (3000-3400lm, depending on company) but gain a little more white/blue color.
In other words, more color=less output; higher kelvins=lower lumens.
If you think you ready to dump a ton of cash for your retrofit, go to hidplanet.com/forums and do your homework.
Good luck.
Old Jan 10, 2008 | 05:15 PM
Default Re: wich hid kit did you use for you retro fit?? (doubleshotz)
Thanx for the info.
03civiclx
Honda Civic (2001 - 2005)
58
Jul 15, 2009 02:30 PM
Ruben19
Lighting
Nov 27, 2007 08:25 AM
mitcho
Oct 15, 2007 06:36 PM
blkgsr03
Sep 10, 2003 09:45 PM
