no crank angle sensor on jdm motor... need help quickly :)
Old Jan 9, 2008 | 02:12 PM
jonathan13's Avatar
Default no crank angle sensor on jdm motor... need help quickly :)
I recently purchased a 99 civic dx with a spun bearing for cheap so i picked up a jdm d15b non vtec to replace the motor. Well i got the motor and just now realized they do not have the crank angle sensor on the oil pump like the usdm motors. my question is can i just get a jdm ecu and will this eliminate my problem or am i going to have to swap oil pumps and use the usdm ecu? thanks so much for any help in advance.
Old Jan 9, 2008 | 03:22 PM
jonathan13's Avatar
Default Re: no crank angle sensor on jdm motor... need help quickly :) (jonathan13)
found ckf bypass trick
Old Jan 10, 2008 | 05:16 PM
rhdekhatchie's Avatar
yeah its the same trick i used and worked flawless no check engine light anymore, hope you got it
Old Jan 10, 2008 | 07:04 PM
jonathan13's Avatar
Default Re: no crank angle sensor on jdm motor... need help quickly :) (rhdekhatchie)
worked great
Old Apr 15, 2008 | 04:48 PM
92integraVTECgsr's Avatar
whats the trick?
Old Apr 15, 2008 | 05:31 PM
el_toro_de_magnifico's Avatar
any link to this said trick?
Old Apr 15, 2008 | 08:54 PM
jonathan13's Avatar
http://technet.ff-squad.com/ckftrick.htm
rig9896
May 22, 2013 04:29 AM
4DRPIMPIN
15
Apr 23, 2004 05:46 PM
CRX T-Si
Jan 8, 2004 05:03 AM
tyflip2
Dec 5, 2003 08:32 AM
