H22 Internal Mods
Old Jan 9, 2008 | 12:52 PM
213374U's Avatar
0x5359-0055
Community Builder
Default H22 Internal Mods
Gonna be picking up my full H swap here in about 2 weeks, my Accord has been down with a thrown rod since last August. Anyway, picking it up from a local performance shop for $1200... a lot less than I had expected to spend on the full swap so I'm gonna have some extra cash. The head is currently separated from the block and I figure while it's apart, I might as well use some of that money to beef things up.
Just looking for some "best bang for the buck" suggestions for around $800. Already set up with the intake and exhaust and will definitely be picking up a header. New to the H side and just need some good suggestions (i.e.- cams, header, rods/pistons, etc.).
Thanks in advance.
Old Jan 9, 2008 | 03:59 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: H22 Internal Mods (213374U)
Nobody huh? Figured with a direct question I'd at least get a few good responses from the H guys around here. Just want a few good options.
Old Jan 9, 2008 | 05:48 PM
2fastGSR's Avatar
King of the One Liners
Get a set of cams.
You cant just get rods and pistons in an H22. The block is made of FRM and you can not use forged pistons with the stock frm sleeves. Sleeving the block alone will cost more than your 800 budget. You can also use special pistons from Mahle that will work with the frm but with the mods you are doing I wouldnt even bother.
Slap the head and block together, Get a decent set of cams, valvetrain and cam gears.
Intake manifold and TB may not be a bad idea as well, but will definitely be over your budget.
Old Jan 9, 2008 | 06:16 PM
98vtec's Avatar
moderator emeritus
Default Re: H22 Internal Mods (2fastGSR)
cams, euroR manifold, tune.
you can find some type S cams, or some lower profile skunks for pretty cheap
manifold is gonna be expensive (500) if you want to buy it ready to be bolted on
tuning can be done with crome.
Old Jan 9, 2008 | 06:43 PM
delboost's Avatar
with the extra cash get it tuned ... if u have money for both get u some skunk cams
Old Jan 10, 2008 | 06:24 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (delboost)
How much more airflow will the mani result in? Gains are decent I'm assuming.
And as for tuning, I just wish I could find a decent crome tuner somewhere in central Texas. From searches in the past (with my boosted F), the nearest decent crome tuner is like 2 states away
She's already got a VAFC in her so I'll definitely get some AFR tuning out of it from the get-go but the overall coverage of crome or hondata will have me upgrading quick.
Old Jan 10, 2008 | 07:24 AM
flyrod's Avatar
Default Re: (213374U)
you could put in type S pistons to raise compression (11:1).
Old Jan 10, 2008 | 07:57 AM
h22crxpwr's Avatar
Default Re: (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">you could put in type S pistons to raise compression (11:1).
i'd rather go with cams. to the OP if its a JDM motor you will be pretty good compression wise already,USDM not so good but not bad either... i going with some cams would be a better decision.. remember to also upgrade the valvetrain. springs and retainers. blueprint sells pretty affordable valvetrain and the Blox cams will work great and be affordable. good luck!
Old Jan 10, 2008 | 06:17 PM
marcusgnf's Avatar
Default Re: (h22crxpwr)
Type -s pistons would make power, and be a better supporting mod for future upgrades
Old Jan 10, 2008 | 06:35 PM
h22crxpwr's Avatar
Default Re: (marcusgnf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcusgnf &raquo;</TD></TR><TR><TD CLASS="quote">Type -s pistons would make power, and be a better supporting mod for future upgrades</TD></TR></TABLE>
with the cost of the pistons and install he could buy cams and make WAY more power... and cheapy ebay header for 70 bucks.. he's on a $800 budget.. might as well get the most out of it with the 800 bucks. pistons are in no way going to give him as much power as the cams will.
Old Jan 10, 2008 | 07:46 PM
213374U's Avatar
0x5359-0055
Community Builder
Pistons and more will definitely come later but right now I just want a little extra out of the motor before I drop it in. I figured throwing another $800 at it would be good considering i'd be spending $2000 total for a full H swap with some decent internals.
Going with the skunk2 pro1 cam setup though, seems to be the way to go to get the best mix of performance and streetability. Now if I can just find a tuner round here
Thanks for the insight
Old Jan 11, 2008 | 04:22 AM
PirateMcFred's Avatar
Search the archives for tuning services. There are a couple in houston if nothing else.
Old Jan 11, 2008 | 10:34 AM
NirVTEC's Avatar
Default Re: (PirateMcFred)
s2s1 or s2p1 cams and tune it.....
Awesome gains from 3000-7000! Add the valvetrain for another 5-700rpms of powerband!
Old Jan 11, 2008 | 05:10 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">s2s1 or s2p1 cams and tune it.....
All the info I was looking for, thnx.
Also, can anyone recommend a company that makes a great equal-length header?
Old Jan 11, 2008 | 05:12 PM
213374U's Avatar
0x5359-0055
Community Builder
Scratch that... just found this thread
https://honda-tech.com/zerothread?id=1437360
Old Jan 14, 2008 | 07:31 AM
NirVTEC's Avatar
SMSP
SSR/DTR
HyTech
Vibrant
RMF
CAMP1320
crazes
17
Dec 30, 2008 01:28 PM
Evil-EK
Oct 4, 2006 06:01 PM
ThE PiMpiN Co
Sep 16, 2005 09:00 AM
three6t
Dec 22, 2004 11:25 AM
Fly1865
Feb 8, 2004 12:32 AM
