h22 timing
i just did a swap for my cb
it cranks but wont start wat are some way of checking timing that work
trying top dead center its ok have not performed spark plug test
TDC your crank and see if your cams are TDC
check for spark
make sure your ignition coil is plugged in ;p
make sure your firing order is right
check fuses
any CEL?
check for spark
check fuses
any CEL?
fuses are good
but turns but no spark
cleaned spark plugs
distributor is top dead center
i have not been able to connect 4 codes
not sure if the firing order is the same as 4 ludes and my accord
coil is plugged in
cleaned spark plugs
coil is plugged in
dmb2424
Feb 6, 2015 02:43 PM
srt4pilot
33
Jun 22, 2009 09:36 PM
purplexs650d
Oct 17, 2006 12:31 PM
