Anyone ever install hood pins?
Old Jun 30, 2002 | 04:37 AM
civiksi's Avatar
Default Anyone ever install hood pins?
I finally got my hood pins, and theres no instructions and i dont wanna **** it up. Is there a site or anything anyone knows of that i can take a look at before i try to do it?
Old Jun 30, 2002 | 10:37 AM
USteppin's Avatar
Default Re: Anyone ever install hood pins? (civiksi)
also interested in this info..
Old May 21, 2003 | 08:29 PM
dubniK's Avatar
Old May 21, 2003 | 09:01 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just use existing holes in your radiator support for the pins. Put a dab of white-out on the tops of the pins and rest your hood on top of the pins. Use the marks that transferred to the underside of the hood to make the holes, and use some primer on the edges of the exposed metal.
Old May 21, 2003 | 09:09 PM
iam7head's Avatar
Default Re: Anyone ever install hood pins? (PatrickGSR94)
forget about the white out, use silicone.
which wouldnt leave a mess after installation.
It's easy to install but hard to get the perfect fits.
just take your time and do it slow.
double check and mark where to drills, drill it slowly or your cf hood will crack on you.
drill the hole small at first then enlarge it so it will fit like a glove.
fryman
Jan 9, 2009 03:21 PM
alacard
15
Mar 22, 2007 10:56 PM
ek44
Jul 25, 2006 10:24 AM
96ej805
12
Jul 29, 2004 09:23 PM
LD_EGSICK
Nov 11, 2002 07:00 PM
