after my rod bearing went out... the motor idles all the way down... why?
Old Jan 9, 2008 | 07:14 AM
pkolaboy's Avatar
Default after my rod bearing went out... the motor idles all the way down... why?
ok... one of my rod bearings went out and i replaced all of them...even my main bearings... but the rod is still knocking. so i am starting out with a .03 or 30,000ths over bearing... but the main thing is all this happened when i changed my oil and oil filter...then the oil leaked out of the filter seal some how... so i figured i lost oil pressure and thats how the bearing spun out i guess... also when i drive the car and the engine is heated up... the car still seems to idle all the way down when i take it out of gear... can someone please tell me what could of went wrong? all the help is needed..
Old Jan 9, 2008 | 07:49 AM
98vtec's Avatar
moderator emeritus
Default Re: after my rod bearing went out... the motor idles all the way down... why? (pkolaboy)
was the rod/crank damaged?
Old Jan 9, 2008 | 08:09 AM
pkolaboy's Avatar
no... just i knew that the two rod bearings spun over and melted to each other... but the crank and rod looked fine... i might have to check again...
Old Jan 9, 2008 | 08:11 AM
117's Avatar
117
If the crank and rod were fine, why are you using an oversized bearing? A bearing that's 0.030" oversized is much, much thicker than the OEM size.
What were the bearing clearances used for reassembly?
Old Jan 9, 2008 | 08:22 AM
pkolaboy's Avatar
well i went to a local import parts shop and they gave me f20 main bearings and b18 rod bearings.. i put them in and it still knocks...so i talked to the honda dealer and the parts manager said i need the exact bearings for the motor...( the matching color and all)... but thats like 300 dollars...
Old Jan 9, 2008 | 08:24 AM
117's Avatar
117
You obviously didn't have a factory service manual did you?
So you "rebuilt" the engine and just toss a random set of bearings into the engine without measuring clearances or anything? If so, that engine probably has more problems than just a little knock.
Chances are the crank is toast if you've run it for any amount of time after this "rebuild."
$300 for bearings is a tad high, it's probably around $200 or so. I'd have to check. However that $300 is going to be cheap compared to the cost you're going to incur by having to get a new engine.
Old Jan 9, 2008 | 08:26 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkolaboy &raquo;</TD></TR><TR><TD CLASS="quote">well i went to a local import parts shop and they gave me f20 main bearings and b18 rod bearings.. i put them in and it still knocks...so i talked to the honda dealer and the parts manager said i need the exact bearings for the motor...( the matching color and all)... but thats like 300 dollars...</TD></TR></TABLE>
do yourself a favor and buy parts made for your motor...unless YOU know it will work.
did you check bearing clearances? how do you know what sized bearing you needed?
Old Jan 9, 2008 | 08:33 AM
pkolaboy's Avatar
Default Re: after my rod bearing went out... the motor idles all the way down... why? (117)
yea but i dont drive the car like that.... i havent driven the car for like 5 months... but the crank seems fine though... that one rod did seem a little bent in when i put the bottom back on the rod... when doing the bearings...
Old Jan 9, 2008 | 08:39 AM
pkolaboy's Avatar
Default Re: after my rod bearing went out... the motor idles all the way down... why? (98vtec)
Yea i think i need to get the right sized bearings for the engine...(h23) i think i need sized bearings because the rod still knocks after ive changed them....
Old Jan 9, 2008 | 08:40 AM
98vtec's Avatar
moderator emeritus
are you serious dude?
the damage done to the crank may not even be visible. I'd say pretty much everything is trashed now
a bent rod with a new bearing is just gonna expletive up the bearing and journal even more.
Old Jan 9, 2008 | 08:41 AM
98vtec's Avatar
moderator emeritus
u could have at the least plastigaged everything
Old Jan 9, 2008 | 08:43 AM
Pilotx1's Avatar
if it looked bent, did you get the rod checked/check it yourself for straightness?
this whole story seems a bit fishy to me....
Old Jan 9, 2008 | 08:44 AM
pkolaboy's Avatar
lol i have a plastgauge now... but it might be to late... i dont noe... i think theres still hope in all this bearing ****... it it comes down to it... ill have to swap...
Old Jan 9, 2008 | 08:45 AM
vinuneuro's Avatar
You should plan to get a new shortblock.
Old Jan 9, 2008 | 08:46 AM
pkolaboy's Avatar
Default Re: after my rod bearing went out... the motor idles all the way down... why? (Pilotx1)
no man the actual rod isnt bent... just when i went to put the bottom part of the rod back on... it was harder then the others to get back on... so i dont think that the rod is acutlly bent...
Old Jan 9, 2008 | 09:00 AM
98vtec's Avatar
moderator emeritus
bent is a general term describing any distortion. When you spin a rod bearing, immense heat is focused onto the rod and journal. Heat causes distortions, especially when a large amount of force is being placed onto that exact area.
the least i would tell you to do is break the block down and have the mains align honed (unless completely screwed) and have the crank journals micropolished along with checking for straighness and runout Gonna need to replace the rod which spun the bearing as well.
Old Jan 9, 2008 | 09:08 AM
92hondalude's Avatar
did you even do anything the the rod journals?
Old Jan 9, 2008 | 08:50 PM
JTCdudeman's Avatar
Master H Technician
Default Re: after my rod bearing went out... the motor idles all the way down... why? (92hondalude)
this years April's Fools Joke is starting way too early...
soon2bdropped
Dec 14, 2010 03:42 PM
SurferDude905
Jun 29, 2009 04:30 AM
Baron55
Aug 28, 2006 12:37 PM
ulemu
12
Jan 3, 2006 12:37 PM
hatchedzex
Oct 13, 2004 03:01 PM
