01 Integra, steering won't return...
Old Jan 9, 2008 | 05:40 AM
quick_ls's Avatar
Default 01 Integra, steering won't return...
I've a problem and cant figure out what the cause could be. What's happening is, when i take a turn, the steering wont return on its own, i have to force the car to straighten out.
Mods:
Skunk2 upper control arm
Skunk2 coilovers/struts.
Both outter tie rod ends have been changed, both lower balljoints changed, both uppers have been changed also.
I had it taken in to do an alignment not too long ago, and they mentioned they could manually turn the tires on their alignment machine, that it took 2 people.
Steering rack and pinion? Lower ball joints? Caster off?
Help... cars in storage but want to get it fixed this now before spring hits.
Old Jan 9, 2008 | 05:54 AM
lmike6453's Avatar
the very first thing i would check would be the srs cable reel to make sure you didn't mess it up and end up having the airbag shoot at you....then while i was that far i would take off the wheel and inspect the steering column before putting big bucks in the car
Drop_A_Dookie
12
Feb 13, 2011 07:56 PM
Annihilator
Feb 9, 2011 12:03 AM
d16efsedan
Jul 19, 2008 11:12 AM
mr_mbuna
Sep 4, 2002 08:43 PM
