TOE ARM ADJUSTER
Old Jan 9, 2008 | 12:03 AM
88 civic ef's Avatar
Default TOE ARM ADJUSTER
I need a new toe arm for my ef and i was wondering which brand would be the best for my car. On ebay i found a WICKED TUNING brand which sells for 70 with shipping
http://cgi.ebay.com/ebaymotors...ZWDVW
and the SPC sells for 170 with shipping
http://cgi.ebay.com/ebaymotors...7.m29
Old Jan 9, 2008 | 12:36 AM
88hbz6's Avatar
Default Re: TOE ARM ADJUSTER (88 civic ef)
Wicked tunning is wat i used when i droped my ef 3 inches. Did u already get ur civic compensator arms.
Old Jan 9, 2008 | 12:47 AM
Default Re: TOE ARM ADJUSTER (88hbz6)
yea i am trying to order some right now but i guess wicked sounds good. Have u got any problems with WICKED ??
Old Jan 9, 2008 | 01:05 AM
88hbz6's Avatar
No i have not had any problems with them. Is ur car lowerd that is the only reason you will need this kit, if iam right this kit is to adjust your camber for your rear tires not your toe.
Camber is the tire contact with the road.
Toe distance between your wheels. front of car: toe in \ / toe out / \
Old Jan 9, 2008 | 06:12 AM
dr_latino999's Avatar
I am currently using the SPC pieces. But as some will say, these are just a bandaid if you can't get everything aligned right.
Old Jan 9, 2008 | 09:01 PM
i did a rear disc swap from a DA where i used everything including the toe arm and many people on HT told me to use the civic one which i dont have anymore so i was thinking to get the wicked or spc toe adjuster cause my tires in the rear looks like this / \
Old Jan 9, 2008 | 09:57 PM
88hbz6's Avatar
I was getting the wicked products comfused, because they sell a toe adjuster and a camber adjuster. Didnt know that, Iam sure it will fix your problem.
I used the wicked camber adjuster for my upper arm, and the civic toe adjuster to correct my alignment.
Old Jan 9, 2008 | 10:51 PM
PDRIFT86's Avatar
I'm currently running Wicked Tuning rear camber and rear toe arms on my 88 crx with no problems. I purchased both on ebay and the quality seems real good so far. I have to get under my car one of these days to inspect everything but the last time I checked nothing was loose just dirty. I wish they made better camber adjusters for the front instead of those adjustable blocks. does anyone have recommendations for front camber correction on a very low car?
Awake64
Mar 9, 2011 07:44 PM
efjones9
Sep 19, 2009 08:33 PM
dplatt
Sep 25, 2003 11:57 AM
Steve91
Oct 10, 2002 01:48 PM
Black R
Apr 18, 2002 05:50 AM
