quick question!! (f2b related)
Probably not if you are comparing to a H22/b in the same hatch. The F22 SOHC head is much shorter than the H22 head. The DOHC is a little shorter than the H22.
I can only hope you plan on using the F22A SOHC, as it is the best of the F series SOHC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G-Man »</TD></TR><TR><TD CLASS="quote">Probably not if you are comparing to a H22/b in the same hatch. The F22 SOHC head is much shorter than the H22 head. The DOHC is a little shorter than the H22.
I can only hope you plan on using the F22A SOHC, as it is the best of the F series SOHC.</TD></TR></TABLE>
If the f22a is the accord vtec motor, than that is the one I have. But if it clears, that I'm all good
thanks!
thanks!
97D16Y7
Apr 17, 2009 06:58 PM
