will 14" steelie fit 90'CRX sitting very low??
Old Jan 8, 2008 | 09:53 PM
racingfan's Avatar
Default will 14" steelie fit 90'CRX sitting very low??
A friend of mine have a set of 14" steelies with stunt tires that he want to sell them to me. I need them badly for this nasty winter. but I'm not too sure if they'll fit my car clearly since the car is sitting so low?
I got Azenis RT-615 mounted on GSR blades on the car right now. they're fit just perfect so I don't why that tiny 14" steelies won't fit?
anyway I just need some advice from ya.
Thanks
Old Jan 8, 2008 | 10:07 PM
STREETWERKZ's Avatar
Default Re: will 14" steelie fit 90'CRX sitting very low?? (racingfan)
what size are the tires on the 14" steelie? crx si's come with 14" wheels from the factory.
I have 14" steelies on my car during the tear down.
Old Jan 8, 2008 | 10:09 PM
wakaranai's Avatar
I don't see why they wouldn't fit. You are running a 15" wheel with probably 205/50/15's right? If the 14's have 195/60/14's on them the overall diameter of the 14's is only going to be .1 inches bigger. So, given this and the fact that most ef's have 14's on them, I'd say yes they fit.
Old Jan 8, 2008 | 10:32 PM
racingfan's Avatar
Default Re: will 14" steelie fit 90'CRX sitting very low?? (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">what size are the tires on the 14" steelie? crx si's come with 14" wheels from the factory.
I believe they're 175/65-14.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">I don't see why they wouldn't fit. You are running a 15" wheel with probably 205/50/15's right? If the 14's have 195/60/14's on them the overall diameter of the 14's is only going to be .1 inches bigger. So, given this and the fact that most ef's have 14's on them, I'd say yes they fit. </TD></TR></TABLE>
Thanks. bro
Old Jan 9, 2008 | 12:01 AM
424racer's Avatar
yeah with no problems.
Old Jan 9, 2008 | 07:52 PM
racingfan's Avatar
Default Re: will 14" steelie fit 90'CRX sitting very low?? (424racer)
Tried to fit them on the car today. the tires was little too tall. I need 13" now.
Old Jan 9, 2008 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingfan &raquo;</TD></TR><TR><TD CLASS="quote">Tried to fit them on the car today. the tires was little too tall. I need 13" now. </TD></TR></TABLE>
why not just raise the car up while its snowy? you dont need to be dumped unless you're a snow plow.
Old Jan 9, 2008 | 09:14 PM
racingfan's Avatar
why not just raise the car up while its snowy? you dont need to be dumped unless you're a snow plow. </TD></TR></TABLE>
Im not driving the car at the snow. I just don't wanna all the salts screw up my wheels.
Old Jan 9, 2008 | 09:17 PM
Im not driving the car at the snow. I just don't wanna all the salts screw up my wheels.</TD></TR></TABLE>
if you arent driving it, raise it enough to put those 14s on it. i'd not that critical to stay dumped.
Old Jan 9, 2008 | 09:22 PM
racingfan's Avatar
if you arent driving it, raise it enough to put those 14s on it. i'd not that critical to stay dumped. </TD></TR></TABLE>
I got springs on the car.
Old Jan 9, 2008 | 09:23 PM
I see.
good luck getting it ready for winter-mode.
Old Jan 9, 2008 | 09:52 PM
Grandhustleman86's Avatar
on my old 14's i stepped down to a 175/60 r14....and i also was dumped.
Old Jan 9, 2008 | 09:58 PM
wakaranai's Avatar
That doesnt make any sense. Your current tire setup should have a diameter of 23.1", While the snow tire setup should be at 22.3"?? I dont get it. I understand that some sidewalls are slightly different even though the aspect ration is the same...
Old Jan 10, 2008 | 02:43 AM
gator88's Avatar
Default Re: will 14" steelie fit 90'CRX sitting very low?? (wakaranai)
if you arent driving it in the snow and just dont want it to have corroded wheels while it sits, put it on jack stands so the preload in the suspension goes down, fit the 14s on just incase it decides to somehow fall off, and be set. If you really arent driving it, it shouldnt be a big deal to do.
Old Jan 11, 2008 | 08:11 PM
racingfan's Avatar
Default Re: will 14" steelie fit 90'CRX sitting very low?? (gator88)
got set of 13s today. fits perfect!!
Blanco'03
Honda CR-V & Element
Aug 12, 2015 03:19 AM
R-81DC2
May 8, 2006 06:56 AM
dfoxengr
Feb 25, 2004 06:56 PM
stRodda
Nov 10, 2003 04:44 AM
R-Adrenaline
Nov 5, 2001 04:57 AM
