turbo ?
i got a 93 integra..stock dohc non vtec. 220k miles. its boosted running 8 pounds right now, i might lower it once i get aboost controller. do you think that my engine is going to blow? cause im hearing from half the people its going to and the other half are saying its going to be mint cause the turbos installed perfect and the engine should handle it. how do u guys think it will be once i get the car tuned and if you really think it will blow what should i do to it..thanks
For starters, you cant lower boost more than the wastegate by means of a boost controller.
Secondly, if the setup is tuned correctly, you have nothing to worry about; however, if its not, you have a time bomb on your hands. Another thing, psi alone doesnt tell us anything. Power is what breaks parts.
Elaborate
Elaborate
First thing I would do is tune it, and not with a VAFC.
Also, get a leak down test done or if not atleast a compression test.
How well has the car been maintained?
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">How well has the car been maintained?Ali</TD></TR></TABLE>
I'm going to go ahead and ASSUME that its not well maintained based on the original post...but hey, i'm just assuming
the car has been maintained great..its had one owner belive it or not haha..i just picked it up and im not really smart with the turbos yet..still trying to learn about them a little more
nope, the car was never boosted before..my buddy just put it in and i havn't started it yet with the turbo..i just need to find a short elbow pipe that will connect the turbo to the intercooler and its all set to go..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">get a leak down test done or if not atleast a compression test.</TD></TR></TABLE>
Also, a valve adjustment wouldn't hurt.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">good tuning is a MUST</TD></TR></TABLE>
x2
Ali
x2
Ali
If it blows during tuning, its due to 1 of 2 factors.
1. Bad tuner
2. Something was overlooked and your engine was doomed from the start
Having said that, i hate tuning because i worry EVERY time it goes on the dyno. Generally i walk down the street a ways and try not to think about it...talk about stress
1. Bad tuner
00 Si
Jun 22, 2001 11:13 AM
