e-85 1600cc injectors, injector driver question
ok say i snag some 1600cc injectors then i need to run a injector driver but then do you run a resitor box too or not ? if i looking for just ubove 500hp on e85 will i need a different pump other than my walbro255 and if so what can i can with out haveing to put a sump in the tank. like can i run the walbro and than another in line pump and than have enough for lets say 550hp? is an braded line rated for e-85 some body told me its not.
I would ditch the Walbro and buy a Bosch044.
And you don´t need a resistor box when you are using a injector driver.
yea but thats a inline pump how am i going to get the fuel out of the tank if there no pump in the tank to get it out? and i am not going to sump the tank
If you have to run 1600cc injectors to supply enough fuel for your needs, you're going to need something more than a Walbro 255. There is now a dual Walbro for Hondas and that would be fine for your goals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkw1 »</TD></TR><TR><TD CLASS="quote">yea but thats a inline pump how am i going to get the fuel out of the tank if there no pump in the tank to get it out? and i am not going to sump the tank</TD></TR></TABLE>
You can get the bosch pump from Endyn, they modified it to fit in tank.
nappyrat
Texas -OK -LA (Sales)
Sep 14, 2008 05:41 PM
KamakazieX
Aug 28, 2004 09:30 AM
