turn signal / side marker issue
Old Jan 8, 2008 | 06:47 PM
i getz da chewin's Avatar
Default turn signal / side marker issue
Integra 1998 LS
I tried searching on here and team-integra and couldnt find a solution to get my turn signals to work again. It all started after i installed my new disc brakes in the front and took the car for a test drive. I had forgot to tie up the side marker turn signal wires back to the fender well so the tire had tore the wire out where i spliced it at the bumper turn signal.Dumb I know.
The hazards and the turn signals had completely stopped working. I checked the hazard fuse in the engine bay and it had popped so i replaced that and the hazards are working again. I then bought another flasher/relay for my turn signals but still no response from turn signals. My friends dad told me there was a switch for the turn signals but im not sure where that is. Could that be the solution and if so could anyone tell me where the location of it is?
thanks in advanced.
Old Jan 8, 2008 | 08:10 PM
Mfoehrkolb's Avatar
Default Re: turn signal / side marker issue (i getz da chewin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i getz da chewin &raquo;</TD></TR><TR><TD CLASS="quote">Integra 1998 LS
thanks in advanced.
--- Since you did some splicing, i would consider you rechecking your wiring. Also, make sure the ends of the wires that go to the plugs are still secure. If your tire was pulling on them, might have done something mean to them. If i remember correctly, there should be green,black,red. They will work as long as the green and red are hooked up. So double check the connections, and your splicing job. If it's not that check to see if it popped the fuse again, if it did. you got a short somewhere. Idk what the elder one means by switch. Maybe a relay of some kind.
I still consider rechecking all your wiring. Since the problem happened while the wires got tugged on, kinda pushing me to think it has to deal with that. Also check bulbs and double check connections.
--- Do your blinks blink faster than normal? ---
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">f i remember correctly, there should be green,black,red.</TD></TR></TABLE>
--- LOL, i didn't notice how stupid i just sounded by saying that haha. Oh well.
Old Jan 8, 2008 | 08:16 PM
Default Re: turn signal / side marker issue (Mfoehrkolb)
im going to re-do all my wiring again with heat shrink wrap as well tomorrow. Is there a fuse for the turn signals? I thought there was only the relay. The car didnt come with the pull down thing for the fuse box in the cabin so im kinda lost in that area. Im a big noob when it comes to fuses and such. If there is a short how does one find its location? The blinkers did flash fast before but that was because my bulbs went out and i had taken them out. I wasnt a running a bulb in either side at the time of the accident.
your EK is rediculously sweet btw
Old Jan 8, 2008 | 08:22 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i getz da chewin &raquo;</TD></TR><TR><TD CLASS="quote">im going to re-do all my wiring again with heat shrink wrap as well tomorrow. Is there a fuse for the turn signals? I thought there was only the relay. The car didnt come with the pull down thing for the fuse box in the cabin so im kinda lost in that area. Im a big noob when it comes to fuses and such. If there is a short how does one find its location? The blinkers did flash fast before but that was because my bulbs went out and i had taken them out. I wasnt a running a bulb in either side at the time of the accident. </TD></TR></TABLE>
--- Shrink wrap would be the best, and i would think there is only a fuse for the relay. If there is a short, the way you know is...... fuse pops :D. How would you find the short? Find out what fuse is popping, and what it does. Go from there check ALL wiring.
And now, CURRENTLY. Your blinkers are at normal speeds when activated? 4 way lights work from the outside and no blinkers? Or No 4way and no blinker?
Ima walk out in my car and snap a picture for you of the fuse box. BrB! :D
Old Jan 8, 2008 | 08:38 PM
Mfoehrkolb's Avatar
Ima walk out in my car and snap a picture for you of the fuse box. BrB! :D</TD></TR></TABLE>
--- I am back from my ordeal, and here ya go.
Picture 1&2
Old Jan 8, 2008 | 09:11 PM
hmm is this off your RS? Arent the fuse box layouts for OBD1 cars different then the OBD2 cars? I think i found that out when i was searching for the solution for my problem. If not should i check the 10a fuse for the turn light? 4 way lights work but blinkers dont work what so ever. Im going to buy new bulbs for bump turn signals tomorrow as well. thanks for the help
Old Jan 8, 2008 | 09:26 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i getz da chewin &raquo;</TD></TR><TR><TD CLASS="quote">hmm is this off your RS? Arent the fuse box layouts for OBD1 cars different then the OBD2 cars? I think i found that out when i was searching for the solution for my problem. If not should i check the 10a fuse for the turn light? 4 way lights work but blinkers dont work what so ever. Im going to buy new bulbs for bump turn signals tomorrow as well. thanks for the help </TD></TR></TABLE>
--- That is from my RS, i didn't take notice you had a 98. I will try and find another shot of someone elses box. I forgot i could do that before i ran to my car lol.
EDIT:
I looked on ebay, i wouldn't quote them or anything. This is what some were advertised under, so maybe/possibly they are the same.
"94-01 Integra underhood engine fuse box panel OEM"
Old Jan 8, 2008 | 10:42 PM
hmm tried to find a cabin fuse box panal on ebay but its only for OBD1 cars or DAs. If anyone on honda tech has a picture of their 98+ cabin panal it would be appreciated. Its going to be a long day tomorrow
Old Jan 8, 2008 | 10:55 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i getz da chewin &raquo;</TD></TR><TR><TD CLASS="quote">hmm tried to find a cabin fuse box panal on ebay but its only for OBD1 cars or DAs. If anyone on honda tech has a picture of their 98+ cabin panal it would be appreciated. Its going to be a long day tomorrow </TD></TR></TABLE>
--- That is my point...... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT:
"94-01 Integra underhood engine fuse box panel OEM"</TD></TR></TABLE>
94-95 = obd1
96-01 = obd2
--- Or am i missing something???? ALSO, it was the interior cover that was shown, idk why it says underhood.
Old Jan 8, 2008 | 11:24 PM
hmm there are other threads refering to a "switch"
https://honda-tech.com/zerothread?id=1845555
im going to see if my buddys dad can just show me.
Old Jan 8, 2008 | 11:49 PM
Mfoehrkolb's Avatar
« Re: Turn Signal Electrical Nightmare (dr_latino999) « » 8:16 PM 12/24/2006 Reply Edit
Quote, originally posted by dr_latino999 »
I'm going to replace the hazard switch on Tuesday once the salvage yards open back up Where is relay on the fuse box, the one on the far left hand side or the one in the middle?
About middle of it.
I wish I had a clear pic of it.
--- Check that relay, and the switch they were tAlking about was just the switch itself.
Old Jan 9, 2008 | 12:12 AM
Naruto's Avatar
Default Re: (Mfoehrkolb)
hmmm that makes me think. Is there a difference between the wiring/ fuse lay out for obd2a and obd2b? I may be mistaken but I think 96 - 97? obd2a and 98-01 obd2b? Or was it 96 - 99 obd2a and 00-01 = obd2b....ah crap I can't remember....
Old Jan 9, 2008 | 12:17 AM
Default Re: (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">hmmm that makes me think. Is there a difference between the wiring/ fuse lay out for obd2a and obd2b? I may be mistaken but I think 96 - 97? obd2a and 98-01 obd2b? Or was it 96 - 99 obd2a and 00-01 = obd2b....ah crap I can't remember.... </TD></TR></TABLE>
yes ive heard something about that as well.
--- Check that relay, and the switch they were tAlking about was just the switch itself. </TD></TR></TABLE>
turnsignal/hazard relay? ive already bought a OEM honda one and still didnt work.
Old Jan 9, 2008 | 07:50 AM
imsickofrice's Avatar
Default Re: (i getz da chewin)
did u check alllll the fuses in the fusebox? get a test light and double check all of the fuses.. if not, idk what to say.. cause when my turn signal went out.. i had to replace someother fuse that had nothing to do with it.. then it started working again.. dont know why
it was the tail light, instrument light, license light fuse i believe.
Old Jan 9, 2008 | 04:59 PM
Default Re: (imsickofrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imsickofrice &raquo;</TD></TR><TR><TD CLASS="quote">
it was the tail light, instrument light, license light fuse i believe.</TD></TR></TABLE>
GENIOUS! well i redid all the wiring for my sidemarkers and turn signals the legit way with shrink wrap and checked every single fuse thats on the car. I found a blown 10a fuse in the cabin fuse box which i replaced. Since i dont have the panal that tells me what the fuses im not sure what i switched out but the turns signals and sidemarkers are now workings. im so glad it was an easy fix.
thanks Mfoehrkolb & imsickofrice
Old Jan 9, 2008 | 07:52 PM
Mfoehrkolb's Avatar
glad to hear you fixed the problem man. sorry i couldn't respond earlier. My computer got mad @ me and i had to reformat the hoe. GJ and have fun.
Old May 15, 2008 | 09:46 AM
good to hear your problem got fixed..
lien
24
Nov 30, 2021 04:10 PM
mr.bronx75
Lighting
Jan 27, 2008 08:50 AM
moleodonuts
Sep 13, 2005 02:00 PM
Electrodynamic
Mar 1, 2005 04:24 PM
BrownGSR
Mar 16, 2004 09:19 AM
