Axle issue
oil is leaking from driver side axle! what can i do to fix this, i have never touched this side axle before but happen to see that there was oil around under the transmission! how can i fix this!
man if your axle has oil in it to leak you got more problems then you know.
j/k. first make sure the axle is seated all the way into the transmission. if it is then you more than likely just need an axle seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">New seal for that axle input, if thats where its coming from.</TD></TR></TABLE>
yep
yep
taimysho0
Jul 8, 2009 01:29 PM
