Coolant overflow line; leaking?
Old Jan 8, 2008 | 04:01 PM
Hardedge's Avatar
Default Coolant overflow line; leaking?
A few days ago I had created this thread: https://honda-tech.com/zerothread?id=2192005
Basically I was concerned because I started to notice large air bubbles being returned to my coolant reservoir. I haven't run the car since then, and today I went to take a look under the hood to find that my reservoir level has dropped almost and inch and coolant is puddling around the lid at the base of the coolant line connection. I had noticed this little bit of puddling before but didn't pay any mind to it. Is this line not sealing, and could that be how I'm getting air into the coolant system? If so, can I just throw a clamp on it or should I go ahead and replace the line?
Old Jan 8, 2008 | 04:16 PM
93whtlx's Avatar
Default Re: Coolant overflow line; leaking? (Hardedge)
Like I say, if it ain't broke don't fix it. I think its broke. I would fix it. (replace the line). I don't play with coolant system. If it even looks like its bad. I change it. See what happens when you change it. Nothing worse could happen. I hope
Old Jan 8, 2008 | 05:34 PM
Hardedge's Avatar
Anybody know if it can be effectively clamped as a temporary fix so I can at least run the car?
Old Jan 8, 2008 | 05:59 PM
pdotjones's Avatar
Default Re: (Hardedge)
i don't see why not..as long as the clamp is tight, and the hose isn't ripped or torn...
Sheraizzle
Aug 16, 2016 12:27 PM
Bulli Kid
Honda Civic (2006 - 2015)
Nov 25, 2008 04:08 PM
Quik89Si
12
Jan 6, 2003 04:44 PM
ScottEK
Oct 30, 2002 09:42 PM
acatak
May 26, 2002 11:58 AM
