oil question
what brand and grade of oil do people normally use for b18c1 and whats recommended. i've been using castrol gtx 10w 30 and a friend said why are you using 10w 30 its thick. he uses 5w 30. someone help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">5W-30 is the recommended weight. </TD></TR></TABLE>
Yep. 5W-30 in the winter.
If it gets pretty hot in the summer, 10W-30 is a good idea.
I also recommend Castrol GTX High Mileage (green bottle) for your 150k motor. Good stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">
i agree with the weights but i wouldnt go with gastrol gtx on high milage enignes bc castrol sysnthetic has this thing about cleaning out motors which casues oil leaks.. just my .02 i wouldnt put it in my motor.
</TD></TR></TABLE>i agree with the weights but i wouldnt go with gastrol gtx on high milage enignes bc castrol sysnthetic has this thing about cleaning out motors which casues oil leaks.. just my .02 i wouldnt put it in my motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmihatch »</TD></TR><TR><TD CLASS="quote">i agree with the weights but i wouldnt go with gastrol gtx on high milage enignes bc castrol sysnthetic has this thing about cleaning out motors which casues oil leaks.</TD></TR></TABLE>
GTX High Mileage is not synthetic
still it son ofthe worse things u can put in your motor. it cleans it out ot well causing oil leaks.. trust me i know from first hadn experiance.
</TD></TR></TABLE>still it son ofthe worse things u can put in your motor. it cleans it out ot well causing oil leaks.. trust me i know from first hadn experiance.
still it son ofthe worse things u can put in your motor. it cleans it out ot well causing oil leaks.. trust me i know from first hadn experiance. </TD></TR></TABLE>
I think it does cause leaks too, but man that stuff stays clean for weeks after I do an oil change. IMO not one of the worst things you can put in your motor
I ran 10W30 when I lived in Delaware. Now I run 5W30 in Washington state. I've always used Castrol GTX and never had a problem.
'98 EX coupe with 145,000 miles on it. I used the same for my '97 EX coupe that had about 86,000 when I crashed it.
If you're having leaks, you probably have issues elsewhere. I find it unlikely that it's your brand of oil.
I also run Royal Purple 10 w30. Alot of people tell me bad things about it, but I have had good. I use to be on my uncle's pit crew at route 66 before i moved. He ran a 72 chevelle and we have run the same motor for about six to seven years now. No rebuilds. It is a street compression motor that he runs low tens high nines all day. So that is why I like it.
