Is a troque plate required when boring/honing an open deck block?
I want to have this done correctly. Doesn't seem like the lack of a tq plate while machining would be as important with open deck as it would be with closed deck, correct?
If you look at bore distortion , most of it occurs near the top of the cylinders when clamping a head, or a TQ plate on. Where do the cylinders meet the block in a Honda design? At the base of the cylinders. Pretty far away from the point of contact between the head/TQ plate & the block. What is the most important portion of the cylinder in regards to making sure it is "true"? The top. It is my opinion a TQ plate is not necessary when doing an open deck Honda block.
There is another technique that seems to work well tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">
"Hot" bore?
</TD></TR></TABLE>"Hot" bore?
we have tested with and with out torque plate. you do not have to have one but the bore does come out a lot better with one. open and closed deck block is no different when it comes to the torque plate
