Random beeping
I was driving home today and out of the blue I start hearing a beeping sound. It went off but would randomly come back on, it sounded like it was coming from the place above the rear view mirror where it tells you which seat belt isn't hooked up (the red lights). It didn't continuously do it and it never lasted the same duration; it just seemed completely random.
No CEL
89 crx si
That's about it, doesn't do it at any certain times really just whenever it feels like it I reckon.
Anyways, is it a short in a wire or has this happened to anyone else? Car has 202k miles on it.
Thanks
No CEL
89 crx si
Thanks
probably that seatbelt indicator beep thing, mine was going off all the time for no reason in my civic, i just ripped the buzzer off the chip and stuck it back in there, and now its quiet
I've actually had a problem with the horn. Everytime I honked it I'd blow that fuse. I had it fixed but it sounds like only one of the 2 "horns" behind the front bumper actually work I reckon I'll look at it again, I fixed a short in the horn and it works but maybe not 100%.
Thanks
Thanks
i also have a 90 crx dx and im having the beeping noise come from the dash area. sounded like the ecu area. beeps like 3-5 times then shuts up for a minute or two and then repeats. i have read ICU problems. my rear defroster doesnt work, i havent checked my inter. wiper setting yet. anyone know? does a 90 crx dx have an ICU???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz »</TD></TR><TR><TD CLASS="quote">the place above the rear view mirror where it tells you which seat belt isn't hooked up (the red lights)
Thanks</TD></TR></TABLE>
It tells you if your seat belt is on or not? my car just beeps 5 times at startup...its a hatch though.
LOL, Guys if you look behing the center console near the back of your radio..you will see a gray box with a clip. Remove the clip from the box and your annoying seat belt noise problems are gone!!!!!!!!!!!!!!!!
mine is not a seatbelt noise. i buckle up everytime i get into the vehicle. the sound is coming from the dash area. noone up here carries an "ICU" by the way my inter. wipers work but the defrost doesnt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">LOL, Guys if you look behing the center console near the back of your radio..you will see a gray box with a clip. Remove the clip from the box and your annoying seat belt noise problems are gone!!!!!!!!!!!!!!!!</TD></TR></TABLE>
That's what mine was, that's what I did. GO ME.
No CEL
89 crx si
Thanks
No CEL
89 crx si
Thanks
Yea bro, I have a 1990 crx and i have the 5 point harness and when i plug in the seatbelt do dad? on the rearview it constantly beeps! I just disconected the plug on it! problem gone.
Speaking of Beeping!, Where in the hell is the tweeter/speaker/beeper whatever you would like to call it located...The one that is generally located behind the steering wheel? i have pin pointed it up in that area. But still have yet to find it...I believe its interlaced with the fuse box???I about to rip my dash out to find it. More details-Its the defualt beeper when you leave the key in the ignition or door opened. Thanks -1990 crx si /2nd-Gen.
i drive a 97 prelude and i have beeping from my dash. it took a while but i discovered the beeping happens when i use my left indicator, and occurs more on cooler days. i dont know why this happens???
I have a Honda Integra 1987 and has just recently a random beeping noise has started coming from the dash, there is nothing mechanically wrong with the car and the noise will randomly stop and start again, HOW DO I MAKE IT STOP FOREVER?????????
There is a correct way to fix this. I need shematics for the entire beeper circuit. It wouldnt be hard to find if there is schematics for the ICU circuit board and all other boards in the car. All we need to do if find the beeper on schematic, see what switches trigger it , isolate them and then start inspecting all other wiring , including connectors, possible trace damage on circuit boards (in ICU ?) or cold solder joints. Or if it is a timer chip that pulses the beeper they may go bad or have bad solder joints or faulty DIP sockets.
guedo148
Aug 2, 2009 12:23 PM
