headlights wont go on help plz
Well ive tied everything i could think of where is the headlight relay for the headlights. Ive checked the fuses and everything still nothing only think i didnt check was the relay but dont know where it is can anyone tell me where it is?
Try replacing the combination switch. You should be able to find one at a junkyard or on eBay.
Try http://www.car-part.com for a junkyard. It's a database of parts available from junkyards nation-wide.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost7177 »</TD></TR><TR><TD CLASS="quote">and what is the combination switch where is it located>?</TD></TR></TABLE>
The thing you use to turn on your headlights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost7177 »</TD></TR><TR><TD CLASS="quote">yea but my turn signals work. Where is the headlight relay?</TD></TR></TABLE>
There isn't a headlight relay.
Just because one part of your switch works doesn't mean another part isn't broken. It's happened to me, and plenty of other people out there.
If you've checked all your fuses, tried other bulbs, and all your wiring is in tact .... then it's your switch.
Gawd.
Gawd.
