Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
loose starter ground wire
Old Jan 8, 2008 | 11:46 AM
lgharis's Avatar
Default loose starter ground wire
Our 2000 CRV recently had the ground wire come loose from the connector on the starter. It is only a blade connector. The first time it happened we had it towed to a dealer and they found the loose wire. To their credit they simply reconnected the wire and called it good. Only problem is it came loose again on Christmas Eve. I found the loose wire, crimped the connector a little bit and put it back on. It seemed to be tight and is still on.
I was just wondering if anyone else has had this problem and if they had any better ideas for a more lasting solution. I thought about soldering the connector on, but then it would be a pain to remove if I ever needed to replace the starter again.
Robert Williams
Apr 4, 2019 08:49 AM
sumoneEK
Aug 13, 2010 09:44 AM
ShinotakuX
Mar 30, 2008 09:00 PM
trianglegreg
Nov 21, 2006 05:56 PM
