NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!!
Old Jan 8, 2008 | 10:55 AM
carlosp38's Avatar
Default NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!!
Well here it goes i have a 95 integra just put in a gsr motor in it well i bleed the clutch and turned on the car but the car wont go into the gear i tried flushing tranny fluid then putting some in .......it only goes into gear wen the car is off dont kno wat it could be let me kno wat you guys think thanx
Old Jan 8, 2008 | 11:06 AM
Jtuned DC2's Avatar
* B A N N E D *
so does it go into 1st gear when the car is on?
Old Jan 8, 2008 | 11:13 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!! (carlosp38)
Can you select gears with the engine off? If so, the clutch is most likely at fault. If you cannot select gears whether the engine is on or off, check the linkage and engine/tansmission mounts.
Old Nov 14, 2008 | 09:48 AM
killacam661's Avatar
Default Re: NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!! (Dogginator)
im having the same problem i changed two trannys, a throw out bearing, clutch slave cyclinder, and a few other things and my car still wont go in gear when the engine is on. everything is torqued to spec but still is being gay. and i just put on a act 6 puck, ima change the clutch today and let you guys know what fixes it.
Old Nov 14, 2008 | 10:05 AM
94VTECoupe's Avatar
Default Re: NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!! (killacam661)
yup i'm going with the clutch. Basically if the engine is always spinning the transmission's mainshaft because it won't disengage, then the gear syncros can't ever match the speeds of the gears because the output end of the transmission is at a dead stop where the input is moving at 900 or so RPM's.
I would check your clutch assembly. Did you install the clutch yourself? or did it come already assembled? If you installed it, make sure that everything is placed correctly, and if not, I would take it apart and look for faulty parts.
Old Nov 14, 2008 | 12:33 PM
twentyhurtz's Avatar
Default Re: NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!! (94VTECoupe)
its an apparent problem, this is not the first time i have seen someone post this exact problem, search it some.
Old Nov 14, 2008 | 12:38 PM
yc_dc4mar's Avatar
Default Re: NEED HELP CAR WONT GO INTO GEAR DC2 !!!!!! (twentyhurtz)
i had this problem. it was my clutch...unfortunately the bastards i bought it from wouldnt let me return it.
Old Nov 14, 2008 | 01:32 PM
lmike6453's Avatar
The very first thing I would do is make sure that you bled the clutch lines properly. Most people that do it for a first time do not and have air in the lines. Air will compress when pushing the clutch pedal, rather than moving the shift fork all the way in.
Old Nov 14, 2008 | 10:32 PM
90Da9Ls's Avatar
i had this exact problem in my Da i could go into any gear when car was off but when i started the car it wouldn't go into any gear i ended up replacing clutch release bearing and it was straight after that
Old Nov 14, 2008 | 10:40 PM
majinsoftware's Avatar
Quite often its the springs on the clutch, They have eather warped or started to pop out and they catch while the engine is on so you cant disengage the clutch.
Old Dec 24, 2012 | 12:27 AM
rob696's Avatar
I have an issue with 98 JDM Integra Type R, 1.8DOHC Vtec, S80. Already replaced Honda MTF but no good. Gears are smooth as butter with the engine cold (I've checked all Gears, 1st, 2nd, 3rd, 4th, 5th and even Reverse) but when operating temp is reached it gets more n more difficult to shift and this isn't a problem with one gear. The shifter takes more effort to put it into gear. There is no grinding, no squealing at all. By the way with engine hot, even if I shut the engine try to shift it is still hard to shift. Please help
Old Dec 24, 2012 | 03:41 AM
B20ztek's Avatar
Try reading the thread you posted in.
oresama
Jul 29, 2018 08:46 PM
Nisif
Oct 14, 2012 11:26 PM
c_kling08
Oct 15, 2009 11:49 PM
Leo C
Jan 21, 2007 09:07 AM
Leo C
Jun 26, 2006 02:22 PM
