TW/FS: 1989 Civic DX (Si)
Make: Honda
Model: Civic Hatchback DX – Clean Title
Model Year: 1989
This Civic was built for track use mainly. There is no sound deadening nor carpet, heater core, blower motor, or anything under the dash for that matter.
It will come with stock rear interior pieces and a set of 1989 Civic Si rear seats.
Asking Price as the car sits: !!SOLD!!
See details below. Thank you.
Car passed smog on 1/17/08….Will come with smog certificate.
Engine:
-D16a6 w/ MPFI
-Reground cam (will also include a stock Si cam)
-High-comp. cylinder head (cylinder chamber was welded and pressure tested by the previous owner)
-ARP rod bolts
-Metal head gasket
-Less than 500 miles run since purchase (original owner had said they only put a few hundred on as well)
-PM6 ECU
Intake:
-Multi-port Fuel Injected
-Enlarged throttle body
-CheckPoint cold air intake
Exhaust:
-DC ceramic header (2-piece)
-Catalytic converter-good (will also come with gutted catalytic converter)
-Greddy SP2 w/ crushed bent b-pipe
Suspension:
-Koni struts (yellow)
-Ground Control specific to Koni struts w/ 400/450 spring rates
-Ground Control extended top hats
-ST rear adjustable swaybar
-Si front swaybar
-Type R/1988 Civic/CRX box type rear LCA
-Front LCA has inner spherical bearings and Mugen hard bushings for the strut fork
-Rear trailing arm has brand new Mugen hard bushings
-Jim-Fab Racing front x-member
Steering:
-OEM outer tie-rod ends (brand new)
-Mugen hard bushings for steering rack mounting
Front Brakes:
-LS uprights
-OEM pads
-Brembo blanks
-Goodwrench SS lines
-Hawk Blues used for 3 track days
-Brembo cross-drilled used for 3 track days
-ARP extended lug studs
Rear Brakes:
-1991 CRX Si rear disk setup
-LS Integra e-brake cables (brand new OEM)
-OEM pads
Cooling:
-Samco upper/lower radiator hose
-10” slim fan (pusher)
-Brand new OEM upper/lower radiator hose
-Inlet and outlet for the heater core have been capped.
Interior:
-Sparco Sprint Jr. driver/passenger seat
-Wedge Engineering seat bracket and stock sliders
-Momo Monte Carlo steering wheel
-Momo hub
-Generic steering wheel spacer
-Civic Si cluster
-Civic Si clock
-Autopower roll bar (5 pt.)
-Sparco 5 pt. harness
Exterior:
-JDM ZC headlamps w/ Raybrig H4H bulbs
-1989 Civic Si front lip (brand new OEM)
-Amber bumper lens (brand new OEM)
-Front and rear mudflaps
-Spoon style side mirrors
-WeatherTech window visors
Battery:
-PC680 Battery w/ SAE terminals
-Die Hard original size battery
Wheel:
-Panasport Racing wheels 14x7
-95% Azenis
-BuddyClub open ended lugs
Items not on the car up for sale and/or included depending on sale price:
-5Zigen 304 Border Max cat-back exhaust
-Race exhaust (consists of a Super Trapp muffler, down pipe, and resonator)
-15x7 TSW wheels w/ Azenis (should be replaced soon)
-PG7 ECU
-D16z6 Unorthodox Crank Pulley
-USDM headlamps and buckets
-OEM airbox
-Brand new OEM radiator support
At Strts of Willow
Misc.
Modified by EF_yo_89 at 9:33 PM 1/24/2008
Modified by EF_yo_89 at 2:39 PM 2/22/2008
Model Year: 1989
Engine:
-D16a6 w/ MPFI
-ARP rod bolts
-Metal head gasket
-PM6 ECU
Intake:
Exhaust:
Suspension:
-Si front swaybar
Steering:
Front Brakes:
-LS uprights
-OEM pads
-Brembo blanks
Rear Brakes:
-OEM pads
Cooling:
Interior:
-Momo hub
-Civic Si cluster
-Civic Si clock
Exterior:
Battery:
Wheel:
-95% Azenis
-PG7 ECU
-OEM airbox
At Strts of Willow
Misc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">nice sleek build bro...how much are you looking for? </TD></TR></TABLE>
thanks man, just taking offers right now.
