anyone familiar with water pump sqealing only at warm temp???
Old Jan 8, 2008 | 06:16 AM
lmike6453's Avatar
Default anyone familiar with water pump sqealing only at warm temp???
so when i start the car nothing sqeaks but when it warms up it sounds like the pulleys are squeaking...but if it were the pulleys, shouldn't it sqeak from even when it's cold? it's a light sqeak and i read on a tsb that i should replace 6.8 ounces of water pump lubricant in place of coolant in the radiator. i called honda/acura for the specific kind and they said they don't carry it so i bought this stuff from pepboys called No Leak. Would you guys recommend me doing this or any other way to fix the problem??
Old Jan 9, 2008 | 05:49 AM
lmike6453's Avatar
bump
Old Jan 10, 2008 | 04:57 AM
lmike6453's Avatar
i just did it last night...will post in here for reference if it fixes problem...
Old Jan 10, 2008 | 03:05 PM
Blahblah718293's Avatar
Default Re: anyone familiar with water pump sqealing only at warm temp??? (lmike6453)
hmm... i would replace the water pump if you dont know when it was done last.
Old Jan 11, 2008 | 04:58 AM
lmike6453's Avatar
i got the car 5,000 miles ago and never replaced it-has 126,000 miles on it...i would think that it would be the pump but then i read this tsb about noisy ones....
http://www.acuraworld.com/tsb/1993/B93-020.pdf
and i used the goldeagle NO LEAK product....still hasnt changed a thing since 2 nights ago...hmmmmhmmm
Old Jan 11, 2008 | 05:41 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: anyone familiar with water pump sqealing only at warm temp??? (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">hmm... i would replace the water pump if you dont know when it was done last.</TD></TR></TABLE>
+1
Old Jan 11, 2008 | 09:52 PM
jaystillidie's Avatar
what about when i hit alot of water ? i think if your talking about the same squeeking noise that goes on when u turn on your car ? and stops a little after you accelerate? i want to know also what it can be because it happened to me once when i accidently went through a ddep water flood ever since thne i can here a small eeeek when i turn on the car nothing long though its just for a split second
Old Jan 13, 2008 | 02:17 PM
lmike6453's Avatar
nope, your problem seems a little different...now i have to look for a diy for the water pump
Old Jan 19, 2008 | 09:24 PM
lmike6453's Avatar
this stuff didnt work....bump
Old Jan 25, 2008 | 09:56 AM
lmike6453's Avatar
bump
Old Jan 28, 2008 | 10:22 PM
lmike6453's Avatar
bump before bed...zZZzzzzz
Old Feb 6, 2008 | 04:21 PM
lmike6453's Avatar
bump
Old Feb 29, 2008 | 06:56 AM
lmike6453's Avatar
bump
Old Feb 29, 2008 | 09:14 PM
95 integra's Avatar
Default Re: (lmike6453)
No leak and lube are different products....get the correct Acura part (online if need be) and rock that out. Ofcourse replacing the water pump isnt a bad idea....126k and its suppose to be done at 90k. I suppose I'd rather do it on my terms then have steam blowing out of my hood, leaving me on the side of interstate one day (been there, done that....it wasnt much fun).
Old Mar 1, 2008 | 02:43 PM
lmike6453's Avatar
yea you're right...what should i use to clean off the residue from the old gasket/how do i ensure a good seal when installing?
Old Mar 2, 2008 | 11:58 AM
lmike6453's Avatar
bump
Old Mar 4, 2008 | 05:23 AM
lmike6453's Avatar
bump
Old Mar 5, 2008 | 05:02 PM
lmike6453's Avatar
bump for any other ideas?
WingedMan
Apr 26, 2021 05:03 PM
new_climber
16
Mar 12, 2018 08:56 PM
Champs32
Feb 13, 2009 11:32 AM
ho_999
May 31, 2008 10:45 PM
cadougherty_67
Mar 29, 2005 06:21 PM
