RC 440cc injector ok for poor man's type R ??
Old Jan 8, 2008 | 04:48 AM
Powered by VTEC's Avatar
Default RC 440cc injector ok for poor man's type R ??
i am rebuidling my b16a sir2 engine with type r intake manifold bored to 68 mm and skunk2 throttle body 68mm. type r cams. type r valves. CTR pistons. aem fuel rail..etc.. would rc 440cc ok with this set up (with an adjustable fuel regulator), too aggressive for n/a setup?? whats the cc number for oem b16a injectors?
thanks
Old Jan 8, 2008 | 04:58 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: RC 440cc injector ok for poor man's type R ?? (Powered by VTEC)
You'll get your best answers in the All Motor forum for sure.
Having said that what I can tell you is that 440cc is a bit much for the build you're talking about. Again the All Motor forum would be THE place to get this info, but I'm thinking you'll get suggestions alone the 310cc mark possibly.
I guess that you could always trim the fuel back with engine management (not a fuel pressure regulator) and run the injectors at less of a duty cycle. I'd say Hondata, Uberdata, Crome, etc. etc. Fuel pressure regulators only offer blanket adjustments, which means that while some parts of the rpm range may be rich others may be lean. Ideally you want fuel adjustments that allow you to change fuel delvery in increments more like 500rpms or so.
Also I'm honestly not sure what stock B16A injectors are rated at cc wise.
Old Jan 8, 2008 | 05:10 AM
Luserkid's Avatar
Default Re: RC 440cc injector ok for poor man's type R ?? (B18C5-EH2)
Depending on your piston selection stock injectors could probably do the trick. If your looking for 250-300whp i would suggest 310s, maybe even 370s. But i really doubt your looking for that with 68mm TB setup. So i say start off with stock, hit the dyno. If it shows you need more setup to 310.
Old Jan 8, 2008 | 08:31 AM
Default Re: RC 440cc injector ok for poor man's type R ?? (Luserkid)
thanks guys. i will get 310cc injectors then.
Old Feb 17, 2008 | 11:03 AM
markcivicsir2's Avatar
i think the stock injectors are 240cc. i'm doing much the same build as you but using skunk gear.i bought 310cc@s for mine.
Old Feb 17, 2008 | 11:09 AM
Schister66's Avatar
Man U FTW
Stock injectors are 240cc and are good to about 180-190whp. If you're looking to make a little over 200whp, then 310cc injectors will work just fine for you. The 440s are too large IMO because they'll flow enough to make nearly 300whp. Having said that, there really isn't a downside to having a slightly larger injector. A 440cc isn't too large to have a decent idle...that's about the only concern when sizing injectors
SpeedRacerEX-R
Jul 29, 2015 08:26 AM
meheartmycivic
Mar 30, 2010 02:48 PM
GSR-DB1
Mar 3, 2010 07:59 AM
turboeg831
Oct 12, 2006 12:20 PM
ITRSpeed
Feb 3, 2004 03:42 PM
