do i have a faulty injector?
when i turn the key to the on position, the fuel pressure goes up, then immediately fall s down to zero. I immediately thought fpr, but after changing it to no avail, i started to experiement. I pinched the return line after the fpr to see if I could stop the bleeding... fuel pressure still falls. So, then i pinched the line from the fuel rail to the fuel filter, the pressure stays the same! BTW, my gauge is on the fuel filter.
So basicalli I know its on the fuel rail... im guessing its an open injector or a bad injector. The car will not start for some reason either... maybe a flooded cylinder or related to the injector issue.
Anyway, any ideas?
Anyway, any ideas?
thats what im thinking.... im really annoyed right now. going to get another set of injectors tomorow and see if it cures the fuel pressure problem. Then i gotta figure out why the car doesn't start.
Still accepting input
Brembomaster
Engine Management and Tuning
Jun 26, 2019 05:00 PM
-[95cxhatch]-
Jul 11, 2008 09:27 PM
-[95cxhatch]-
18
Jul 11, 2008 02:29 PM
